Mitsubishi VS-50705 50" Rear Projection Television Logo
carlos rhodes Posted on Oct 07, 2013
No picture just green timer/light going on then off
Sony BRAVIA KDL-52V4100 won't turn on. Strandby red light always on and Pic OFF/TIMER orange light blinks.
Sir
PIC OFF/TIMER LED-------Green or Orange LED-------
* Lights up in green when Picture Off is activated
* Lights up in orange when the timer is set
When timer is set, the LED remains lit even
when the TV is turned off
thanks
M Nasir
1helpful
2answers
I have a 56' that wont show picture
Power board is bad.. I had the same issue.
On/off green light flashes. Picture comes on for
the timer is set for a short time, try to get to the menu quick and turn off the timer it may take several tries.
1helpful
Sound but no picture - won't stay on
you may check your lamp first. other than that i would say a faulty mains board.
Blinking green light under 'Timer' flashes there is no picture
If you have a green blinking LED that runs continuosly, its the widespread problem of failures of capacitors on several circuit boards in the TV. Currently Mits is having authorized service centers remove the chassis and send it them for rebuilding. Its an expensive and time consuming repair.
Turn on the TV and only Timer light is on , no sound & picture
after holding down the menu and device the led will blink a two digit error code such as 3 blinks pause then 4 blinks then repeat that sequence a couple of times. Need that blink code to help let you know whats going on. The 34 code means lamp abnormality which translates to the power Pwb capacitors have most likely failed.
Green timer light blinking constantly, no picture
You need the V21/V19 DM repair kit thats available at the following link, it contains the parts and step by step instruction CD so you can do the repair yourself. Its listed under their repair Kit category.
http://servicemanuals.vstore.ca/
2answers
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
