When we turn the tv on a few minutes later it cuts off and the green power light blinks for a few minutes then the tv cuts on by itself. It keeps turning on and off but the green light just keeps blinking. Someone please help.
I went thru this a couple of days ago. The repairman change the bulb and my TV was fix in 15 Min. I too have a Sony 60 inch WEGA. Now that I know I can change the bulb myself, but there's a hazmat issue on the bulb. goog luck.
SOURCE: Tv cuts off and green light flashes
The Best Solution worked perfectly, I replaced the XL2200 Sony Bulb and the TV is up and running again!
Thanks for the help.
BobE.
None TV is powered off. Normal operation.
Green TV is powered on. Normal operation.
Green 1. TV just plugged into AC outlet.
Wait until blinking stops before turning on (approximately 1
minute). Normal operation.
2. AC just restored after power failure.
3. TV Rebooting after System Reset was
used.
4. TV Rebooting after power fluctuation
or receiving abnormal digital signals
from digital channel, or digital device.
5. You have begun the procedure to
update software from an authorized
flash memory device.
For detailed information, see the instructions that accompany
the authorized software update. IMPORTANT: Do not
use unauthorized software at any time.
Green TV just powered off and lamp is
cooling.
Starts to blink 30 seconds after turning off TV. TV can be turned
on before blinking starts or after blinking stops, but not while the
indicator is blinking. Normal operation. hope it helps regards shaun
Green TV powered off and auto-on timer is set. Normal operation. TV can be turned on at any time.
Same TV with same exact problem. Someone on line said they changed out the bulb and that fixed it. We tried putting in a nw bulb and, sure enough, that fixed it.
I have a 42" Sony Wega rear projection LCD TV. When you turn it on it will work for a few minutes and then cut off for about a minute or so then come back on. This happens repeatedly. Could someone help. Thanks
When I turn on my TV, the green light blinks multiple times, and the TV makes a lot of clicks. Sometimes, the TV turns on and sometimes it doesn't. I also unplug it and plug it in again after several minutes, after doing so, it sometimes turns on and sometimes doesn't.
