Pantech Renue P6030 Cell Phone (AT&T ) Logo
Ms Kayd Selden Posted on Oct 07, 2013
Set correct time on phone - Pantech Renue P6030 Cell Phone (AT&T )
Cliche-Name
Level 1:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Contributor 39 Answers
  • Posted on Feb 13, 2014
Cliche-Name
Contributor
Level 1:
New Friend:
Greenhorn:
Answers
39
Questions
0
Helped
3881
Points
68
Well if you are asking for how to set the time on your phone, then you should be able to go to settings and then there should be something that says change the time. After that find the clock that has the right time and your set :D Hope this helps
How do you change the time on an Avaya 5420 phone
Avaya Phone Change Date and Time
Avaya/Lucent Partner ACS Phone System
  1. Press Feature and dial 00.
  2. Press the left intercom button twice.
  3. To set the time, press # and dial 103. Enter the correct time using a 24-hour format.
  4. To set the date, press # and dial 101. Enter the correct date using MMDDYY format.
  5. Press feature and dial 00 to save.
Setting the time and date on Avaya phone systems - TSRC.com
Where is OK button when setting date and time
Correct my date and time to update my phone ' Windows ...
www.windowsphone.com/.../correct-your-date-and-time...
Windows PhoneIf you're having trouble installing a Windows Phone update, correct your date and time settings manually.
How to Change the Date in Android ' Chron.com
smallbusiness.chron.com > ... > Setting Up a New Business Basics
Android phones normally pull the date and time from the Internet, but if there's a problem with the signal ... Click the "Settings" button to open the Settings menu.
2013 Models - How to Set the Date and Time on your ...
? 0:52
https://www.youtube.com/watch?v=jTSZwCLSiTk
Dec 4, 2012 - Uploaded by Panasonic Canada Help
In this video we will explain how to Set the Date and Time on your Panasonic Cordless telephone, models KX ...
How to Set the Date and Time on Your iPhone - For Dummies
2answers
I need to reprogram my 5655 so that the correct date and time is announced by the system
The time and date is set at the base unit.
Press the TIME/SET button
Press the TIME/SET button again
Press the CHANGE button until the correct day is announced
Press the CHANGE button until the correct hour is announced
Press the CHANGE button until the correct minute is announced
Press the CHANGE button until the correct year is announced
Press the TIME/SET button to finish and the current clock setting will be announced
You can hold the CHANGE button down when setting the minutes or year to increment in steps of 10. Following is a link where you can download the manual.
http://att.vtp-media.com/ecp/documents/product_Product/614/UserManual/2041/e5655_manual_bkm.pdf
Time on phone keeps changing and doesn't stay when I put the correct tome in...which I shouldn't to do right....its suppose to be automatic but its constantly giving me the wrong time...help please
Your secondary battery located inside your unit which is for correct time display maybe drained. I have the same problem with my phone. After I had it replaced by a technician, my phone clock display is now working nomal. Another option if you don't want your secondary battery replaced is setting your phone to automatically detect your network's time. Go to settings, look for time and date settings and locate the automatically update time or something like that. Everytime you turn on your phone, it should automatically detect and display a correct time.
He time on my motorola shows 16:10. How do I correct The Time please?
Most Motorola phones have a feature of "auto-adjustment" for correcting time. If this feature is enabled then your phone will not show the option to set the time manually. In order to correct the time manually you need to disable the "auto adjustment" feature. After disabling this manual adjustment settings will automatically come.
Hope this will help....cheers:)
2answers
HOW DO YOU SET THE DATE AND TIME?
It should be in 'settings' on your cell phone menu. Search around your phone. It could also be in 'organizer'. On my old one, it was in 'organizer', and once I went there, there was a 'set date and time' button. Here is the answer from the Vtech website: "Make sure the answering system is on. Press [Time/Set]. The system will announce the current clock setting, then announce "to set date and time, Press Time/Set". Press [Time/Set]. Press [Change] until the system announces the correct day, then press [Time/Set]. Press [Change] until the system announces the correct hour, then press [Time/Set]. Press [Change] until lthe system announces the correct minutes, then press [Time/set]. The system announces the current clock setting. Note: You can press and hold [Change] to advance the mninutes in increments of ten. "
2helpful
Can not figure out how to change the time on the phone
Clock is not in the phone, its in the PBX!
You must set the Time in PBX.
Press "PROG"
Press "*", "*"
Enter password (default 1234)
Press "0", "0", "0"
Press "ENTER"
Set Y-M-D
Press "NEXT"
Set Time
Press "ENTER"
Press "CANCEL"
Press "EXIT"
Time display
Check the network time settings. If the phone time is "Set by network" maybe the network time servers are messed up. Set the time on the phone manually and see if the problem is fixed. If the phone is already set manually see if setting it to Set by network will force it to keep correct time, but the internal clock should be more stable than that. You may need to get a replacement if these tricks don't work.
AT&T cordless/answering machine: 4695
From the user manual, you need to use the MENU, CHANGE and TIME/SET keys Set the Clock 1 With answering system on, press MENU until the system announces,?Change clock.? 2 Press CHANGE until the system announces the correct day, then press TIME/SET. 3 Press CHANGE until the system announces the correct hour, then press TIME/SET. 4 Press CHANGE until the system announces the correct minutes, then press TIME/SET. The system announces the current clock setting. 5 Press an MBOX/STOP button to exit programming. Hope this helps
Top Pantech Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
Are you a Pantech Cell Phone Expert? Answer questions, earn points and help others
