SOURCE: removal of evo6 gearbox
is the bellhousing removable? also check the flex plate isnt bolted on
SOURCE: Front-left Outer CV Shaft Disconnected from inner-CV shaft
If memory serves me right the axel is bolted to a plate on the front differenchel and a large nut on the end that goes thru the hub bearing, if you take the whole shaft out( both ends) i see no problem running it temporary without it.
SOURCE: I get a loud humming
I would say it's the bearing because the CV joints will usually make a clicking noise when turning right or left........Hope this helps.
