there is a problem on tension adjustment and setting of stitch
try to learn on actual video how to set thread and sewing, log on www.youtube.com on search box type Husqvarna sewing machine
and theres a lot more tricks on sewing.have a nice day don't forget to rate me. thank's
I had a problem similar to this-- when sewing, tons of thread was bunching and looping out of the stitches instead of a nice neat stitch. I finally figured out that this old metal bobbin I put in was incompatible. I switched to a plastic bobbin (the kind like that which came with the sewing machine) and the stitches looked fine.
it's very possible that the machine is slightly out of time & needs to be service at a sewing machine shop is the fabric & thread & needle compatable with each other? did you use every thread guide when threading the machine? is the bobbin in correctly? is the bobbin warped?
Hm, wondering if it could be the presser foot pressure setting. Most machines have this capability where the amount of pressure applied to the feed dogs can be increased or decreased. You might check your owner's manual,.
It does not matter what pattern you select, if you have the stitch width dial on 0 or set on straight stitch then that is all it will do, to do patterns you need a close stitch length about 2 or if it is not numbered get the stitches close to suit yourself and the stitch width on the widest number.
Yes, it does. There are a couple of reasons the bobbin thread could be bunching up on the underside of the fabric. It could simply be that the machine needs cleaning. Take the bobbin assembly out, brush all the old lint out as best you can, reoil the machine once it's all clean, and make sure there aren't any little bits of thread caught in the bobbin assembly. Rethread the machine (carefully) and change the needle. This solves the problem usually--especially if the machine was sewing along fine and the problem develops suddenly. '
The other thing to check is your tension. It could be that the top tension is too loose. But different color thread in the top and in the bobbin, stitch a few inches (be sure to held the top and bobbin thread ends behind your needle as you start to stitch) and check. WIth the pressure foot down, adjust the tension, and stitch again. Keep stitching, checking, and adjusting until you see little if any bobbin thread on the top or top thread on the bobbin.
Another thing to reminder: use the appropriate thread and needle for the fabric you're sewing.
Let me know if this works, ok?
Make sure that you use the F foot when using decorative stitches.
The stitch balance my be off. Remove the accessory bin and you will see a large plastic screw with a + and a - and an arrow. Using a coin, turn the arrow to the center and test. Turn the arrow towards the + to stretch the pattern out.
If this doesn't work, it must me calibrated internally and requires an experience hand.
Okay I think i can help- i have mastered the lower bobbin threading after 4 hours and am now trying to sew but thread keeps bunching up. Anyway you have to line finger of boobin in the top notch, this will keep your bobbin from getting stuck. Hope i helped Lesnbek
