HI, Do the following for unlock the parental control. For this you should need the remote for the DVD payer. 1. Press the set-up button on the remote (set-up display will come on the TV screen ) 2. Using Right arrow button or Left arrow button select DVD Setup menu 3. Using Down arrow select Parental control and press Enter button 4. now you can change the parental rating using up down arrows If it ask for password the read the following carefully and do the same and enjoy your videos. PARENTAL CONTROL LEVELS 1-8
The Parental Lock allows you to limit the use of your DVD
Player to only those DVD discs that do not exceed the rating you specify. When
the Parental Control is set, DVD discs that support this feature will play only
after the password has been entered. However, typically only discs produced by
major entertainment companies support Parental Control. Discs not supporting
this feature will be "immune" to Lock-Out.
When you attempt to change the Parental Control setting, you are
prompted for a password. This of course makes sense, as this option would be
useless if your kids could enter the Setup Menu and disable it! If there is no user
password set, you'll be prompted to enter a new password. Choose a 4-Digit
numeric password and write it down in Case
you forget it. Key in the password and press ENTER. After the password is set,
press ENTER on the CHILD option. You can choose from 8 levels of Parental
Control, corresponding to the standard rating system in the USA. The available
levels and their equivalent ratings are listed to the right.
PASSWORD - CHANGE
Here is where you can set an additional password to the
default factory password. The procedures to change an existing password or
enter a new password are the same - you
must enter the OLD PASSWORD, then key
in your new password twice to confirm. If you are entering a new password, or replacing a password you
have forgotten, use the factory default
password of 3351 as the OLD PASSWORD. If you are changing a previously entered
password, you may enter that value as the
old password.
A. Remember to keep
in mind that the key to the the factory default password of 3351
B. Once the factory password has been changed, you should keep the password
written in a safe location as a reminder if needed Ajin
On the Nintendo DSi Menu, use the stylus to select the settings ("wrench") icon.
Select the right arrow twice to reach the third page, then select "Parental Controls."
Select "Yes," to change the parental controls.
You will be prompted for your 4-digit PIN.
Select"Clear Settings," then select "Yes" to confirm.
If you don't know the PIN, select "I forgot," then select the empty text box for the answer to the secret question and enter it using the on screen keyboard. Select "OK" to continue.Select
If neither the secret password or the pin is known you many need to call Nintendo who will be able to reset your password remotely, this is there number 1-800-255-3700
Actually its, 'select' then '7444', and all that does is reset the password. Press
the SELECT button and enter the 4-digit number "7444" whenever the
Parental Control display asks you for your password. The old password
is deleted. You will then be prompted to enter a new password, enter
whatever number you want, something like 0000, or a number that is easy
to remember. If you wish to turn it off, just set it to off and forget
about passwords. Notes - When you play DVDs which do not have the Parental Control function, playback cannot be limited on this player. - If you do not set a password, you cannot change the settings for playback limitation. -
Depending on the DVD, you may be asked to change the parental control
level while playing the disc. In this case, enter your password, the
change the level. When you stop playing the DVD, the playback
limitation level returns to the original setting.
After changing DVD settings: To
save your changes, be sure to eject the DVD before pressing the RESET
button or turning off the unit with the MAIN POWER switch. Please note
that changes will not be saved if you reset or turn off the console
without first ejecting the DVD. Sony Playstation 2 manual, pg. 19
for the phillips and magnavox tv sets the code is 0711, then open the menu setting restet the code to something easy to remember , or what i would do is completly disable the child lock by going to that option in parental settings.try it hope it works!
If you forgot your password for this feature, press the following buttons on the remote, one at a time. (Note: You must be in the password entry screen) Press, Mute, Display,Clear and Reset, this unlocks parental controls and you can now re-enter a new password. OR TRY THIS.. Press and hold Menu on the TV AND volume down on the remote for 3 seconds. Nothing will appear on the screen, and the Parental Controls will unlock, and you can re-enter a new password with the LOCK PARENTAL CONTROLS
Bill
