SOURCE: Whirlpool Double oven - control panel stopped working
Atlanta...sounds like you may have a power supply problem or the panel is bad. Cut the power, open the unit up and see if there is a fuse in there or a reset. No good? Then replace the circuit board. They just, well, die sometime. Happened to my microwave. Some units may be available remanufactured. Look around on the web.
SOURCE: Whirlpool GBD307PDS Electric Double Oven
I fixed my problem by disconnecting the control board, cleaning all the contact points (including the ribbon cable) with alcohol and reconnecting everything as tight as possible.
I did notice that one of the contacts had become very corroded, so I scrubbed this one for a while. Prior to this I had done some selective unplugging and replugging (ribbon cable in particular) to no avail (each of these attempts powered on to beeping and no display).
Not a fancy solution, but it did work!
SOURCE: Whirlpool RBD305PD has error F2E6 error on control panel
When this code appears and display is going blank too, it is always the control board. The only option is to buy a new one or get it repaired. It can be fixed quickly and reliably. www.fixyourboard.com
SOURCE: Oven display went blank. Has Power.
Hello, The first thing I'd look at is your owner's manual to insure the timer hasn't been set to "Sabbath" mode accidently. If that is the case you could experience a "no display" scenario. The manual will also explain how to enter/exit the "Sabbath" mode. In the event the timer itself is at fault ( i.e. the display transformer gone bad ) it will have to be replaced or (if an available option exist's for your timer) have your timer rebuilt. Hope that help's and please take a second and rate the info provided by me here at fixya. Thank you and good luck. macmarkus :)
SOURCE: Whirlpool electric double oven #RBD305PDQ14 control panel blank
The control panel part on my Whirlpool double oven (part #8302319) went blank six months back. Replaced it. Asked if there was a warranty on the part, was told no there was not. Yesterday, the six month old control panel went blank. Disappointed that Whirlpool manufactures such garbage.
