You can download GE
owner's manuals and installation instructions here.
If the installation instructions do not have the template, you can also find helpful
exploded view diagrams and order needed parts by entering your full model
number here.
We're
happy to help you with free advice and we'd appreciate your thoughtful
rating of our answer.
Very angry. Fairly new, little-used Spacesaver Microwave [3][Clock][Surface Light] buttons now do not work. We never even press [3], just [1] and [2] to warm sandwiches. Unplugged for an hour. Still not working. Everything else works. We never use anything else. Bad solder joint in circuit board or keypad? Thank you.
open door to unit get model number and got o searspartsdirect.com and enter it in to get part number and prices...... or shop locally,, also repair clinic.com also sells parts and shows pictures of most hope this helps let me know
Just to let you know, I'm a general contractor in the state of michigan.And after I didn't hear from you
I just made a phone call to reasure myself on my question, because it's been a while since I installed
kitchen cabnits.Almost every spacesaver cord is located on righthand side.
If you have the experience with discharging a capacitor and you have a (VOM) Volt Olm Meter. Unplug microwave, discharge capacitor, and check the resistance of the two thermal cut-off discs by removing the lead and set VOM to RX1. If you don't get a reading of zero, replace the discs. For part go to www.partselect.com and enter your model number. If you found any of these suggestions helpful, please rate my solution. D. Lange
You may be looking for the philips flat head 1/4 x 28 tpi (threads per inch) threaded bolt that is
about 4" long. The tip of the bolt does not have threads, which aids in
locating the threaded hole in the top of the microwave:
General Electric's part number for their OTR microwave cabinet mounting screw is WB01X10180 (or AP3205964
or 942461 as listed on some repair parts sites).
A set of three is GE's p/n WB01X10125 (or AP3185225
or 910236 as listed on some repair parts sites).
This flathead screw is used on most Advantium Speedcook microwave ovens such as the SCA2001BSS03 or SCA2000FWW03 or SCA2001KSS03.
Need to find out the model for the serial number listed for this item.
005662
