If it backfires, check for manifold leaks, fuel mixture is too lean, timing is off, make sure it isn't spitting liquid into the cylinders and the LP is the right pressure, and the vapour coil is working
Firing order is
1-3-7-2-6-5-4-8 Passenger side of engine starting at front and going
back is 1-2-3-4 Driver's side starting at front going back is 5-6-7-8.
YEP A CRACKED DISTRIBUTOR CAP.CAUSE BACK FIRING AND CROSS FIRING PLUG WIRES.BAD PLUG WIRES WILL CAUSE BACKFIRING.WRONG HEAT RANGE PLUGS WILL ALSO CAUSE BACK FIRING.
you must have the throttle at full at all times when under load driving and mowing, back fire is do to much fuel. if your running throttle at full than look at the carburetor and then the wiring (short)
