Find out your model number on your pump by checking the hayward site, for the super pump the parts manual is http://www.hayward-pool.com/pdf/Parts%20Diagrams/Super-Pump.pdf
Once you figure out the part number for your super pump you can call a local pool and spa shop and they will order it, you can google the part number, buy it off amazon (personal choice), or call hayward at (908) 355-7995 (U.S.) to buy a replacement
SOURCE: Hayward 1 hp super Pump just hums then shuts off.
turn shaft manually wiyh pliers if somthing is stuck in propeller this should clear it
SOURCE: new 1.5 hp super pump hayward, blows circuit when
Recheck your wire connection on the motor. You likely put both your line wires on the same terminal. If not, try finding a local warranty center for a repair or replacement... http://www.haywardnet.com/locator/
SOURCE: Need wiring diagram for Hayward dual Super 2 speed
You need 4 wires to wire the 2 speed pump. You will also need a 2 speed time clock.. Tightwatt or intermatic. The wiring diagram is on the motor.
SOURCE: I HAVE A HAYWARD SUPER PUMP SELF PRIMING MODEL :
What is broken in your motor? Don't count it out until you have your pool place give it a check. If it is dead, get a 1 1/2 Hayward Super Pump just like the one you have.
Thanks for your interest in FixYa.com
SOURCE: I have a 1 hp
If you've never done it before, it can be a bid deal. You will need to get the exact replacement motor (1hp square flange), a shaft seal, impeller wrench, and be prepared to replace o-rings and rewire the new motor. If you're not comfortable dealing with electrical/mechanical, you're better off getting a service tech to help you out.
