Question about Dometic 3105457.000 Duo-Therm Penguin RV Air Conditioner Non-Ducted Ceiling Assembly
No heat when knob in the opt heat position. i have a duo-therm brisk air roof mount
  • Dometic Master
  • 6,674 Answers
If no element installed and connected, heat setting will not work.
Posted on Jan 16, 2014
6ya staff
SOURCE:
Don Berry
  • 230 Answers
SOURCE: will not shut off
Sounds like a stuck relay on the unit itself. Maybe there is a short in the control wire that comes from the thermostat that activates the fan.
The thermostat probably has one hot wire at all times. The thermostat then chooses which wire to send the voltage down based on your selection. One of those wires is probably for the fan only. Make sure that it is in good condition (no bare, pinched or wires)
Posted on Jun 17, 2008
Anonymous
  • 4 Answers
SOURCE: problem with rooftop air conditioner duo therm brisk air box kit
Try having a professional check that the collant lines have not perished. Also have them check the thermostat and that there is actually gas in the system. The warm air suggests that the unit has no gas.
Posted on Oct 30, 2008
Anonymous
  • 340 Answers
SOURCE: My duo therm brisk air roof mount ac unit is
yep have the leak fixed and properly charged.
Posted on Jun 19, 2009
carlsbiz
Carl
  • 1124 Answers
SOURCE: i have a duo therm brisk air model 57915-001 leak
Could be the drain path is clogged.. Take the cover off & see if you can get it cleaned..
Posted on Jul 09, 2009
motor1258
Mike Butler
  • 6674 Answers
SOURCE: My Duo-therm Brisk-Air by Dometic rv ac wont cool.(The fan runs )
Usually just listening closely will give you a rough idea where to look for problem. When you have the fan on and switch to cool, (with temperature turned down low obviously) do you hear any type of "moaning" sounds from AC unit, or see lights in RV dim slightly indicating that compressor is trying to engage? Is the breaker tripping when compressor tries to engage? Do you hear a "click" from AC unit when switched to cool? If none of that happens, then I'd start thinking thermostat, or compressor relay. Normally if it's a faulty capacitor, the compressor will try to engage but will make a "moaning sound" and usually trip the breaker due to excess current draw. Someone experience in electrical should be able to test relays etc, but whoever does work on it, should be aware that those capacitors, as well as hydro in general are very dangerous to work with. The ("zap",- Shock) that you can experience from a capacitor or hydro, can be fatal.
Posted on May 30, 2010
How do I Wire a duo-therm RV heat pump
see wiring on panel make sure dip switches correct
Feb 26, 2015 | Dometic 459196 Duo-Therm Brisk Air...
Duo Therm 3109228.001
sounds like thermostat issue not communicating with relay modeule
Aug 01, 2014 | Dometic 3109228.001 Duo Therm Comfort...
Duo therm heat pump blowing hot air only
relay module or communication cable from t-stat issue.
Apr 02, 2014 | Dometic 459186 Duo-Therm Brisk Air...
Dometic 457915 roof air wont shut off automaticly
check fan wiring on board possible bad control board
Jun 13, 2012 | Dometic 457915 Duo Therm Brisk Air...
Duo-therm brisk air AC unit leaks water into my RV when it rains
take the cover off and make sure the drain line is clear on top off RV.
Nov 15, 2009 | Ovens
Dometec Briskair Duo-Therm Compressor won't quit running
Have you taken return air filter grille down at ceiling assy, & cleaned filter with dish soap & warm water? Check & see if you see little probe sticking out in behind there, and wipe it carefully as well, and make sure it's lined up to sense air flowing through there. Take a flashlight & look up into coils at front for lots of dust on them as well. Perhaps a thorough cleaning of all coils is in order if you say there's lots of dust, as choking airflow off with dust & dirt, will only shorten life of unit & use more hydro than necessary.
Jul 07, 2009 | Heating & Cooling
Dometic 3105457.000 Duo-Therm Penguin RV Air Conditioner Non-Ducted Ceiling Assembly Logo
762 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
Thomas F. Schneider
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
