The humidifier does not collect water at all
Hi,the lack of water in the bucket, may be a result of the humidity
setting on the unit being to high. Try setting the level at 45% or
lower. Also, be sure there's adequate air flow around the unit itself.
It should remain a minimum of 12' from a wall or furniture. 24" is
better.
If the above doesn't solve the problem, try this at home
test. Place the unit in the bathroom, turn it ON and set the level as
low as possible. Turn the shower ON hot enough to generate steam. Do not
turn ON the bathroom's exhaust fan. As you exit the bathroom, close the
door. Wait 15 to 20 minutes, before returning to the bathroom. When you
do, turn the shower OFF and allow the unit to run for several more
minutes. Then check the bucket for water. If there is any sign of water
in it, it's working fine. It was probably a case of the humidity level
being set to high the first time.
If there was no water in the bucket, the refrigerant gas in the cooling coils and the compressor may need recharging.
Hope this helped your to troubleshoot and solve the problem. Please let me know. Thanks.
