Computers & Internet Logo
anilstalin Posted on Oct 05, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I cannot cannect my 6230i nokia to my computer when connected your device is reported windows error 43
Sandeep Kumar
Level 2:
Sergeant:
  • Expert 252 Answers
  • Posted on Oct 05, 2013
Sandeep Kumar
Expert
Level 2:
Sergeant:
Answers
252
Questions
0
Helped
31425
Points
553
Error Code 43 is a Device Manager error that means the following:
Windows has stopped this device because it has reported problems. (Code 43)
When you get this error with USB devices it's because one of the drivers controlling the device notified the operating system that the device failed in some manner. It will be of issue of the loaded corrupted drivers. You should reinstall the operating system or reinstall the drivers that doesnt have virus or file damages.
Panasonic kx f612 code 43 error
Windows has stopped this device because it has reported problems (Code 43).
Code 43 can be summarized in two words: driver problem.
I can't help you any more without knowing which Windows version you are using, but the Panasonic website is
http://panasonic.net/pcc/support/bfax/
1helpful
My Plantronics C420-M is not recognized
How To Fix Error Code 43 Windows has stopped this device because it has...
If Windows Device Manager is giving a code 43, this means the hardware is reporting something wrong when trying to connect. I'd do the following (and also check the attatched link for reference ;-) )
  • Unplugging the headset, restarting the computer, then plugging the headset back in.
  • Make sure the USB connector on your headset (and the USB port you're putting it in) is undamaged, and not dirty.
  • Try connecting the headset to another USB port, and another computer to see if you're able to reproduce the issue there (if not- it may just be the USB port(s) on your computer that you're plugging the headset into that's failing.
If all else fails, it may be time to purchase a new headset ;-)
Connection pc usb
This code is a hardware device error code..so this could mean that your device driver hasn't been installed properly on your computer or your computer is not seeing the necessary drivers for your phone.
so this is how you resolve it ok: open device manager and
  1. To open Device Manager, click Start, click Search programs and files, and then type Device Manager. A list of available matching items appears above the search box; click Device Manager. Device Manager opens with your computer name at the top and a list of devices that are installed on your computer beneath your computer name.
  2. Locate the malfunctioning device in the list of devices, right-click the device, and then click Uninstall. When a warning message appears that you are uninstalling a device from your system, click OK. Device manager uninstalls the device.
  3. Right-click your computer name in Device Manager and click Scan for hardware changes. Device manager scans your system and automatically reinstall your device.
  4. Right-click the device and click Properties. On the General tab of the device Properties dialog box, in Device status, you should see the message This device is working properly.
If the steps above do not resolve the problems with the device, , use the taskbar icon to safely eject the device, then unplug the device from the computer.If the device includes a drivers disk, ensure that you have it handy to install the device drivers; otherwise, Windows should automatically locate the correct drivers and install them.
If you do not have a driver disk and Windows cannot automatically detect the drivers, it means that your hardware manufacturer has not uploaded the drivers for your device to Windows Update. If this is the case, you must go to your device manufacturer web site to download or request the most recent drivers for your device.
A lot of my favorite music is on my flash drive,error code 43 message
Code 43 Error Message
The Code 43 error is one of several Device Manager error codes. The Code 43 error will almost always display in the following way:
"Windows has stopped this device because it has reported problems. (Code 43)"
Details on Device Manager error codes like Code 43 are available in the Device Status area in the device's properties
rror Code 43 Troubleshooting
  1. Restart your computer if you haven't done so already.
    There is always the chance that the error Code 43 you're seeing on a device was caused by some temporary problem with the hardware. If so, a restart of your computer might fix the Code 43 error.
    Note: Some users have also reported that powering off their computer completely (not just a reset) and then turning it back on has corrected their Code 43 issue, especially if it exists on a USB device. In the case of a laptop, turn it off and remove the battery, wait a few minutes, and then put the battery back in and start the computer.
  2. Did you install a device or make a change in Device Manager just before the Code 43 error appeared? If so, it's very possible that the change you made caused the Code 43 error.
    Undo the change if you can, restart your PC, and then check again for the Code 43 error.
2answers
What is code 43
Details on Device Manager error codes like Code 43 are available in the Device Status area in the device's properties: How To View a Device's Status in Device Manager.
Cause of the Code 43 Error
A Code 43 error is generated when Device Manager stops a hardware device because the hardware reported to Windows that it's having some kind of unspecified problem.
This extremely generic message could mean there's a true hardware issue or it could simply mean that there's a driver problem that Windows isn't seeing as such but that the hardware is being affected by.
Error Code 43 Troubleshooting
Depending on the changes you made, some solutions might include:
How do I fix the msi motherboard windows 7 USB error 43?
How to Fix a Code 43 Error
  3. Reinstall the drivers for the device. Uninstalling and then reinstalling the drivers for the device is a possible solution to a Code 43 error.
    Important: If a USB device is generating the Code 43 error, uninstall every deviceunder the Universal Serial Bus controllers hardware category in Device Manager as part of the driver reinstall. This includes any USB Mass Storage Device, USB Host Controller, and USB Root Hub.
    Note: Properly reinstalling a driver, as in the instructions linked above, is not the same as simply updating a driver. A full driver reinstall involves completely removing the currently installed driver and then letting Windows install it over again from scratch.
1helpful
Device not detected
Whenever windows reports a code 43 error msg is because the device driver is corrupted or is reporting a failure, re-install the driver if error persist contact the manufacter of the device showing the error. Best regards Luis!
Top Nokia Computers & Internet Experts
k24674
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
