I cannot my phone to computer when connected errors windows stoped worked beacuse the device is reported code 43
This code is a hardware device error code..so this could mean that your device driver hasn't been installed properly on your computer or your computer is not seeing the necessary drivers for your phone.
so this is how you resolve it ok: open device manager and
If the steps above do not resolve the problems with the
device, , use the taskbar icon to safely eject the
device, then unplug the device from the computer.If the device includes a
drivers disk, ensure that you have it handy to install the device
drivers; otherwise, Windows should automatically locate the correct
drivers and install them.
If you do not have a driver disk and Windows cannot
automatically detect the drivers, it means that your hardware
manufacturer has not uploaded the drivers for your device to Windows
Update. If this is the case, you must go to your device manufacturer web
site to download or request the most recent drivers for your device.
SOURCE: nokia n91 cannot connect to pc thru usb cable
plz connect the data wire to the phone and also connect it to the PC go to connectivity and choose pc suite or data transfer or data storage or mass storage
SOURCE: nokia n72 pc suite problem
my nokiaN72 pcsuit does not work properly & display an error of pcsuit file in mobile is missing.
SOURCE: problem in connecting nokia n72 with pc..
pc suite install after n72 sofware insert cd rom now data cable conected phone to pc find new hjadware plse search install the driver file, two times try it
SOURCE: when i am connecting my n72 with my pc a massege
Remove Totally and Re-Install your Nokia PC Suite and Drivers first, then follow the On-Screen instructions to connect your Phone to your PC, at the same time, also try to use a different USB prot this time around.
Hope it helps.
SOURCE: Media problem
General system error means it's software is corrupted, just reprogram it. It cannot detect by pc because it have no identity at, just reprogram it and it will work fine, maybe it's infected with the virus while you're synchronizing with your pc.
The Code 43 error is one of several Device Manager error codes. The Code 43 error will almost always display in the following way:
"Windows has stopped this device because it has reported problems. (Code 43)"
Details on Device Manager error codes like Code 43 are available in the Device Status area in the device's properties
