Dewalt DC925B Heavy Duty Xrp 18V Cordless Hammerdrill/Drill/Driver Bare Tool Logo
A
Anonymous Posted on Oct 05, 2013
Dewalt 18v charger led blinks indicating power line problwm
4 Related Answers
Soulvisitor
Soulvisitor
  • 1113 Answers
  • Posted on Jan 30, 2008
SOURCE: 18v. charger (dewalt)
I did a little hunting and it seems you really want to use your 110v charger on a 230v supply.....
So you could use a transformer (LINK)
or you could get a local power supply pack.
Read the label on back of power pack that attach's to wall socket and charger base, see what input it can handle, some gear can handle like 110v-230v, others cant ie will read 120v
Any adaptor that puts out the same output as the original would work ie 18v DC 2.5 amps is your specs i beleive so use a transformer or another suitable adaptor
Please check my quoted specs are the same as listed on power pack of your charge ie I am assuming you are using your 110v A.C. to 18v 2.5amp D.C power pack
Anonymous
  • 313 Answers
  • Posted on Jun 21, 2008
SOURCE: i HAVE A DEWALT DC729 18V DRILL
is this a north american model.all i can find is model DC727 & DC728 model. charger model 9116 & battery is DC9096 may work.charger volts 110v ac. if your buying the individual part like batt & chgr its more expensive than buying the whole kit is cheaper. hope i answer your question
emissionwiz
Marvin
  • 85242 Answers
  • Posted on Nov 07, 2008
SOURCE: Dewalt battery charger
You will need he correct charger, the 24V will destry a very expensive battery.
Anonymous
  • Posted on Aug 28, 2009
SOURCE: My Dewalt 7.2-18v charger model #dw9116 is giving
It means there is too high or too low a voltage coming into the charger. Check your chord.
I had the exact same problem. After using the necessary security bit to crack mine open, I found that the large capacitor inside had come loose and needed to be re-soldered.
That fixed my charger.
2helpful
Dewalt DC9096 18V High Capacity XRP Batteries. Which is the correct charger for DC9096 battery please?
Question edited for a lot more clarity. All questions need full 'make model (what it is)' please.
Question moved from Garden to make model category.
It is this one with wildly differing prices!
https://www.google.com/search?q=Dewalt+DC9096+charger
Why is my battery charger not working?
If the charger is not working the input lines must be check for continuity on the both the lines, preferable one wire might be damaged hence it is not giving supply to transformer.....
Why does battery charger blink twice no matter where its plugged in?
You may have a failing capacitor on the secondary side of charger power supply circuitry. The output voltage will be low or have a lot of ripple; this would cause the error detected. Pictured below is a bad electrolytic capacitor next to several good ones (this is not from a battery charger). Notice how the top is bulged upward instead of being flat - it indicates pressure caused by the capacitor burning out.
There are other failures that could cause this error code, but this one is highly probable.
My Brand new Ryobi 18v lithium-ion battery P104, I bought this three years ago and just now needed it. I opened it from the blister pack it was in and I tried to charge it. When in the charger the red...
get the new charger; and consider returning to store or manufacturer.
if you have the black charger, throw it out
you need the green/two-tone charger for ryobi one 18v
Mar 18, 2017 • Drills
I have 32 dewalt 18v dc9096 batteries and 1d dewalt 18v dc9099 battery. I tried charging them and back to back they all start off charging fine then charging light speeds up as to suggest their all bad. ...
May read instructions and see if charger is compatible of charging the two types of batteries you are charging ,,,,I have 32 dewalt 18v dc9096 batteries and 1d dewalt 18v dc9099 battery
Sep 27, 2017 • Drills
1helpful
When do you know the battery is fully chaarged
on the charger there is a red LED that blinks while it is charging when it is fully charged it will not blink usually about 1 hour to charge a DeWalt 18v battery
3helpful
HOW WILL I KNOW IF BATTERY IS BAD OR THE CHARGER
ON UR CHARGER U WILL FIND: Diagnostics with LED indicator are 5 indicators to communicate battery charge status: charged, charging, power line problem, replace pack, and battery too hot or too cold.
Top Dewalt Drills Experts
Sean Wright
Sean Wright
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
