No problem with heater, in most cases.... Just acting normally.
"LO" is simply informing you that the Heater is not sensing proper water flow through it! A Flow Problem.
A special sensor, called a pressure switch is this source. But... That does not mean it is bad - No, it is in most cases just doing its job!
Most common reason - Dirty Filter.
A good cleaning of the cartridges, or maybe a breakdown and recharge of a DE Filter, or a good cleansing backwash of your sand filter, will remedy this situation.
Or... Check for any OTHER reason or situations water flow may be reduced through the heater:
Good Luck - hope this helped.
SOURCE: Hayward H250 giving me a "LO" error code and does not turn on.
9 times out of ten this means that you have a faulty water pressure switch. It could also be a limit switch, or air pressure switch. Make sure the filter is cleaned, and all valves are in the correct position. Once you are CERTAIN that water is flowing through the heater, you will need to short each individual component to find the faulty one.
SOURCE: Error code LO
Is the heater installed indoors?? if so you'll need a vent pressure orifice kit.
if not check your water press. (below 18 PSI on filter) Place filter on "recir" if it fires and stays on . it's the pressure.
check to see if all connections a set tight hi-ltd switch wire harness etc.
SOURCE: 1 year old hayward h1001d pool heater clicking
Actually, the clicking is likely causing the shaking. Inside the manifold of a H100 is a stainless steel diverter plate that send some of the passing water into the heat exchanger and lets the rest past and back to the pool. When it breaks, you will hear a 'clicking' noise at it rattles in the water path. When it breaks, the flow to the heat exchanger is intermittent and you will begin to boil the water, causing the shaking. This situation is dangerous, especially without a pressure relief in the heater or pipe. As long as your water chemistry is sound, Hayward will usually cover this under warranty even if the unit is over a year old. Contact them to get a factory authorized repair rep out at: http://www.haywardnet.com/locator/
SOURCE: Pool Heater with communication (CE) Error
Code "CE" stands for communication error and describes a fault between the mother board and the display. I doubt it's the relay causing it though...
SOURCE: CE error code on hayward pool heater
CE= Communication Error between Control Module
and Display Interface Assembly
1. Disconnect and then reconnect power to heater.
2. Check for faulty wiring or connection.
Inspect Display Interface Wiring. Ensure Display Interface Plug is securely attached to Control Module. .
3. Control Module and/or Display Interface Assembly
are defective.Replace Control Module and/or Display Interface Assembly.
Here is a linkt oH aywardmanuals:
http://www.haywardnet.com/inground/products/manuals.cfm
