SOURCE: EPSON R1800 END OF SERVICE LIFE
You have a few choices on this one.
1. The SSC utility mentioned by Jacklee366 is usually the first port of call but it may not work in some situations. Worth trying regardless
2. Epson have an official reset utility which is available to North American printer owners who have a valid serial number (back of your printer).
You just fill out this form and you will then get access to the utility (the one eagleflh/bos_dsl is reselling with his kits)
3. You can also get access to the official service utility that service engineers use on these printers... A copy is available here.
IMPORTANT: This utility is a lot more powerful than the other two and requires a bit more hoop jumping but it can resolve the maintenance request very efficiently. Whatever you do, read the readme files and take your time if you opt to use it.
Hope that helps.
SOURCE: two red light blinking
Do you see any flag message like " end of service life-------". You should find a resetter for the printer, its a utility program.
Or its a paper jam, or dirty ink chip connector.
SOURCE: green & red light is blinking
If you try to print and it say "end of service life ........thing" . You have to reset the printer counter to 0 count.
Use a third party software for this, key in in your web search bar " epson reset software" the upper most link is the one, try to read the procedure.
Hope you get it easily.
SOURCE: 2 red lights are flashing on my printer epson R265(END OF LIFE TIME SERVICE)
Reset waste ink counter. Find at indoreset.blogspot.com
