Radio Shack Pro-94 Scanner Logo
james france Posted on Oct 04, 2013
I dont know how to program my pro94 - Radio Shack Pro-94 Scanner
I dont know why im getting cussed out from someone using "text plus" i dont know who they are but what can i do to find out? i dont have text plus on my cell and dont know who it is?
These people could be hacking into your phone's main database and installing a temporary "text plus" program, but making it not show up on your phone's app list. I don't know how to get rid of this temporary program, you should consult a cell phone manufacturer.
Jul 30, 2014 • Cell Phones
I dont know how to program my pro94 scanner
I HAVE THE SAME THING WITH MY SCANNER, IF U FIND OUT HOW TO DO IT, WILL I PASS IT ON TO ME?? THANKS HOPE U HAD A MARRY XMESS
I want to remove programs that i dont use to free up space but dont know what programs to remove
Here's a simple to use all in one freeware program you can use on new and old machines to do a removal of programs/junkware, PC DECRAPIFIER : http://pcdecrapifier.com/download ALSO, another freeware program that has many useful tools to remove junk, CCLEANER: http://www.filehippo.com/download_ccleaner/ For further assistance, respond to this post.
I try to reset my Pro94, turn off, press 2 and 9 and turn on .. then show "LOAD" in the dispaly and 22222 after ... I turn off and turn again ,,, The scaner get stuck in a strange trunking mode and i cant...
You need to press the 2 and 9 keys and hold them in while you power the scanner on. Once you do that the display should show CLEAR for about 5 seconds while it completes the reset function.
Bill B
My PRO94 Scanner beeps about 5 times after every transmission. I know that it can be corrected because it happened before but I don't remember how to do it. It had to do with pressing a button while...
To RESET your scanner:
- Power the unit OFF
- Press and hold the 2 and 9 keys while you power the unit ON
- "CLEAR" will flash on the display for about 5 seconds as the scanner clears and resets itself.
- Do not power the unit OFF until the CLEAR message stops flashing
NOTE: This procedure will clear (erase) all data that you have programmed into it, so be prepared to reprogram everything.
Need the manual for your PRO-94? You can download and print it, at no cost, here:
http://support.radioshack.com/support_electronics/doc61/61172.pdf
Bill B
Listening in since the 60's
Dont know how to program
I dont know what kind you have,but all program about the same way. Lets say you have a digital, look to see if there is a switch in the back,push pro. means program, knowing what freq.you want. Or you can push scan, with your squelch turned down till no noise is heard,when you hear the station you want.push program button. thats all it is to it, but like i say ,dont know what kind it is. .....hope this helps.......
Pro94 will not power up
Have you tried new batteres, or plugged in the external power supply?? Also, try plugging/unplugging the external connector because it may have dirty terminals inside. Good luck!
2helpful
2answers
Need instructions on programing Radio Shack Pro 94
Radio Shack has a website will ALL their manuals... Click HERE and you'll find the pro94 on the list and it will give you a full manual.
Have a blast!
2helpful
2answers
Deleting Programs
2nd
del
yes
do the del yes as often as needed to clear each program.
Top Radio Shack Radio Communications Experts
John
John
xxxxxx xxx
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
