Hi. I have lenevo T410 and whenever i start my laptop, it shows me the Vertical line on the screen. could you please tell me if whats the solution for this ?? thank you.. Jaival Mehta
SOURCE: visual problem with laptop screen
Generally a screen defect.
You can attempt to reconnect the cables going from the system board to the LCD by removing the screws on the bottom for the Keyboard, Palm rest, and bezel. The system board connection is hard to miss, usually centered near the top on Lenovo's.
SOURCE: My laptop is a T60. Blank Screen
You may have a LCD screen with a faulty inverter or a faulty CCFL
lamp. Please click on this link and follow my instruction to
determine the fault and possible fix :-
http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
SOURCE: There is a pink line on top of my screen of my
Sorry to say that this is an indication that the LCD display is failing in that one line. It doesn't
mean that other parts of the display will fail. It may work this way for years to come. Unless it is really annoying or covers more than one single line, such as an inch or so, it isn't something that will cause damage to your laptop. I wouldn't go to the expense of replacing the LCD over one line.
Testimonial: "thks "
SOURCE: lenovo G450M screen has a yellow vertical line at the center of the screen
cool is it really
SOURCE: lenovo z570 screen is getting grey lines problem
it may be the actual video cable going from the board to the screen which would make sense if you've had to have the screen replaced 3 times. the cable may have come loose, or it may have gotten damaged during one of the transplants. unfortunately the only way to test it is to either put it in an identical laptop or try a new one.
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
