Husqvarna 150BT 50CC Gas Leaf Backpack Blower 180 MPH - Manufacturer Logo
callum alan reiner glover Posted on Oct 03, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
If i pull back the trotal on my husku boy 50cc to fast it just bogs out and will cut out it never uste to do this it was siting it my shed for about 6 moths ive cleand the fiter and put fress 2 stroke in it and dos enny one net the corect carb set up
Steve Reardon
Level 2:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Expert 96 Answers
  • Posted on Oct 03, 2013
Steve Reardon
Expert
Level 2:
New Friend:
Greenhorn:
Answers
96
Questions
Helped
29773
Points
141
With todays gasoline it turns to what is called varnish very rapidly and more than likely some of the fuel that set in the carb over those 6 months has turned into a gummy varnish so the carb probably needs cleaned, If it is not to bad you can probably adjust the carb with the air/fuel mixture screws and keep it running well till end of the season, shouldn't take more than 1/8 to 1/4 turn though. I hope this helps
If you need further help, I’m available over the phone at https://www.6ya.com/expert/steve_f5a6ca85b5d1ffc9
1helpful
Hi, anyone know what the factory carb settings are for an aeon mini kolt 50cc. Having problems with getting it started, changed spark plug and battery
Two-Stroke Scooter / ATV Carburetor Settings And ...
? 4:37
https://www.youtube.com/watch?v=A1vRMERs4RQ
Jun 2, 2012 - Uploaded by 90GTVert
Part 2 of a 4 part video detailing all of the basic settings and ... Two-Stroke Scooter / ATV Carburetor Settings ...
Fix your Mini bike Carb - bogging, cutting out etc - YouTube
? 4:51
https://www.youtube.com/watch?v=lbtDMFUiD0k
Aug 15, 2011 - Uploaded by Cpt MishMash VonRandom
If you are having trouble with your mini bike/quad whereby its difficult to ... Two-Stroke Scooter / ATV ...
quad 50cc carb Questions & Answers - Fixya
www.fixya.com > Forum > Tags
50cc carb wondering what the factory setting is for a 2002 50cc Kawasaki kid's ...aeon mini kolt 50cc quad will rev a little then cuts out no power Likely a lean ...
Aeon mini kolt 50cc quad will rev a little then cuts out no ...
Does a husky boy 50cc have a reed
Since your Husqvarna is a two stroke engine there is almost certainly a reed valve between the carburetor and the cylinder.
Husqvarna husky boy 50cc My 6 year old son has a husky boy 50cc it starts up an ticks over fine but wen he turns the accelerator the engine starts to cut out then when he releases the accelerator it fires...
If equipped with a spark arrester then you should remove, clean and reinstall. If you don't have a spark arrester then you need to have your carb looked at
Jul 18, 2014 • Garden
Wean u pull back the trotal on my husky boy 50cc it just bogs out and will cut out but if u pull it back verry sloly it is ok
Check that your fuel is getting to the carburettor.
Check that the carburettor bowl is not full of water, most carbs have a small screw in the bowl to allow drainage.
Pete
Oct 03, 2013 • Motorcycles
2answers
Keeway matrix 50cc scooter cuts starts to cut out after it gets warmed up
CHECK VOLTAGE WITH VOLT METER AND GAS/OIL MIX COULD BE RUNNING ROUGH
1helpful
Aprilia mx 125 bogs down while riding then cuts out
Dont waste your time looking for something else. Go ahead and pull the spark plug and do a compression test. It should have at least 100psi. If not,its time for a top end rebuild. It gets worse when it gets hotter because the ring gap expands,and loses what little compression it has. Best to check the compression and rebuild the top end now,before the piston or rings break,and cause lower end engine catastrophe...
Bog when trying to mow
you are cutting to much grass & it isn't kicking it out fast enough out of deck which will bog it down it might help if you clean out the bottom of the deck & also dont cut really low if grass is really tall also cutting wet grass will aslo cause the bogging if i can further help e-mail me wade at [email protected]
Jun 26, 2009 • Garden
2helpful
2answers
Top Husqvarna Garden Experts
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Thomas Perkins
Thomas Perkins
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
