Pool & Spa Logo
Happy Molly Posted on Oct 03, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is the difference between a sauna and a Turkish bath?
Daisy Pane
Level 2:
Guru:
  • Expert 97 Answers
  • Posted on Oct 03, 2013
Daisy Pane
Expert
Level 2:
Guru:
Answers
97
Questions
Helped
72434
Points
375
Saunas can reach different levels of humidity, and accordingly, they are set at different temperatures.
A traditional sauna is between 70 and 100 degrees Celsius, while a Turkish bath, in order to approach the wanted 100% humidity, has a temperature of around 40 degrees to compensate the steam.
Hi, Do you a cap of some sort to block off pipes tha are left after removing pump?
Blade valve is the best part for this if there is enough room to fit it in. Be sure nothing else is in the way before putting everything back together. Good luck, Tim
Jan 06, 2019 • Pool & Spa
tip
Sauna Heater
Oil and Gas Sauna Heaters
Oil and gas heaters are the least popular heaters used in saunas.
One reason is because they're relatively inefficient compared to the others.
Some people even complain about the odor associated with the burning fuel. If they're properly vented, oil and gas heaters should have little or no unpleasant smell
Electric Sauna Heaters
Electric heaters are the most popular used in saunas.
They're easy to control with user friendly touch pads that include a timer and thermostat, and light switch,
They're also efficient and cost just pocket change to operate.
Electric heaters have controls that include a timer, thermostat, and light switch.
Wood Burning Sauna Heaters
If you have a house in the country or easy access to fire wood, a wood burning heater is a great choice for a sauna.
A wood heater may also be a good choice if you have an outdoor sauna.
Wood burning heaters don
on Jan 08, 2011 • Heating & Cooling
Heilsa Pellet Stove Manufacturers Information
pellet stove tp440 Pool & Spa Heaters Questions & Answers ...
www.fixya.com > Forum > Tags > pellet stove tp440
Pool & Spa Heaters pellet stove tp440 questions and answers. ... for a manual orinformation on this stove it is an older stove we just don't know how old. ... heilsa pellet stove model qcps-28000 my pellet stove is smoking how to change ...
General Infrared Sauna Heilsa Sauna Supplier, Find Best ...
www.alibaba.com/general-infrared-sauna-heilsa-sauna-suppliers.html
Suppliers who can match your search. .... Outdoor Spa,Sauna Room,Jacuzzi,Swimming Pool,Sand Filter .... Infrared sauna room,Portable steam sauna,Infraredheater,Pellet stove,Clothes dryer ..... updates on topics such as trending hot products, buying requests and supplier information - sent directly to your email inbox!
Good Quality Far Infrared Sauna Supplier, Find Best Good ...
www.alibaba.com/good-quality-far-infrared-sauna-suppliers.html
Suppliers > .... Outdoor Spa,Sauna Room,Jacuzzi,Swimming Pool,Sand Filter ...Infrared sauna room,Portable steam sauna,Infrared heater,Pellet stove,Clothes dryer ...compare heilsa infrared sauna with good infrared sauna accessories ..... buying requests and supplier information - sent directly to your email inbox!
Jan 06, 2016 • Pool & Spa
3answers
What is a sauna?
"A sauna is a small room or house designed as a place to experience dry or wet heat sessions, or an establishment with one or more of these and auxiliary facilities.
A sauna session can be a social affair in which the participants disrobe and sit or recline in temperatures typically between 70 degrees C (158 degrees F) and 100 degrees C (212 degrees F). This induces relaxation and promotes sweating.
Saunas can be divided into two basic styles: conventional saunas that warm the air or infrared saunas that warm objects. Infrared saunas may use various materials in their heating area such as charcoal, active carbon fibers, and other materials."
Oct 03, 2013 • Pool & Spa
1helpful
2answers
Sauna
I think you have the wrong category.
1helpful
What does "prr" mean when displayed on the LED readout of the Mr. Steam control panel?
Hi my name is Mike I am with Mr. Steam Product Support. PRR is a code that shows up on our Steam Bath controls it was not used on our Sauna's. The PRR means there is a problem with the temp sensor on the control.please call me at 800-767-8326
1helpful
Guess Steel Water resistant is not water resistant!!!
Water resistant does not mean water proof. You should never wear this watch while bathing, swimming or in sauna.
Any watchmaker will be able to remove any condensation and dry out your watch - no matter you are in the U.S.A. or Romania.
Find your nearest watch repair shop and ask for help.
Rate, please.
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
