SOURCE: Need system recovery disks
Yuo can call sony to order them just pay the shipping on them as I did when mine got cracked, all you have to do is provide the model and serial number and they will send you out new disks, Thanks and have a good day
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
SOURCE: Sony Vaio VGN-FS980 laptop recovery disks
Check your user manuals and see if there is a recovery partition mentioned in there. If there isn't then you will need to buy an operating system cd and reinstall from fresh.
SOURCE: I am looking for sony viao VGN-325E drivers can I
click here
select your operating sytem and download drivers.
SOURCE: Need service manual or instructions on replacing
The hard drive is inside of the laptop and not accessible from the outside. The way to get to the hard drive is to take out all the screws from the bottom of the laptop, take the keyboard out and there may be some screws there that need to be removed. The dvd drive needs to come out and where the dvd drive normally is, check for screws there.
At this point you can remove the top cover assembly and you will see the hard drive. Remove the screws that are holding the hard drive in place and then it will come out.
Testimonial: "Thanks I realize that the unit needed to be seperated however without a service manual there may be some important tips that could be missed."
SOURCE: i need audio driver for Sony Viao VGN-SZ430N win
I had the same proble... and was SOLVED:
1-Download the propiate Audio driver from the VGN-SZ430N XP Support driver
2-Download Legroom Universal Extractor. Install the software.
3-Extract the driver using Univeral Extractor.
4-Browse through the extracted folder: TEMPEXEFOLDER; and then run the "setup" file from there.
4-It will install this way (you will see a quick splash screen of the Audio driver brand).
