Televison & Video Logo
jomar jamon Posted on Oct 03, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My sony bravia LED flat tv goes on and standby then on and then stanby again..and afterwards stucks on standby at all.Is the system controller has failure or its power supply?
Level 3:
Top Expert:
  • RCA Master 76,851 Answers
  • Posted on Oct 03, 2013
RCA Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14986955
Points
237762
Before go, the standby/power LED will blink to a certain times, and these blinks are called blinking codes, and are fault indications. From the number of these blinks occur at one time switch ON, you can get an idea about the fault circuit stage inside the TV. If you wish to get more details about these blinking codes, check this link. if you're sound in electronics, you may get it repaired by yourself.http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
3 Related Answers
Anonymous
  • Posted on Jul 09, 2008
SOURCE: Sony Trinitron Wega kv-36fs120 wont turn on, standby/timer LED flashes 9 times.
1. Place set on flat solid surface (garage floor or driveway).
2. Bang into it with SUV 3 or 4 times.
3. If set fails to respond, crush against garage wall or drive over it
Anonymous
  • Posted on Aug 31, 2008
SOURCE: Won't Turn on, standby LED lit
HI,
I am having the same problem, any solution? Thanks! -Steve
Anonymous
  • 6784 Answers
  • Posted on Jun 21, 2009
SOURCE: TV won't turn on, standby LED starts blinking
HI, this is the result of an unstable power sector in this unit. the fly back is malfunctioning and, you will need to replace it asap. i will list the part number below and a link to a site as well. you can purchase this part on-line if you wish.
FBT ASSY NX-4521//X4
Sony Part Number: 1-453-310-11
CLICK HERE TO ORDER
2helpful
2answers
My 15 month Celcus LCD423D913FHD tv will not turn on. The standby light is lit and will flicker but will not power up the tv. What is the likely problem?
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Sony KDL-32S3000 BLINKS 5 TIMES STUCK STANDBY MODE
Remove all speaker wires and try again. If it unlocks one or more speakers are bad. If not service required for amp. Good luck.
1helpful
Sony Bravia KDL-55nx720 My tv is stuck in standby mode. Blinking twice.. Would replacing the power supply possibly fix this problem? Please help.
Normally yes. Blinking twice is power protection trip. Look first for open resistor, broken fuses (and short circuits or broken transistors / ICS if thats the case).
1helpful
How solve my problem w/ lcd sony bravia 32in raster 3x show then goes to stanby the blinks
I will need the model number of the Sony and also how many times does the light blink? Thats an error code so the number of blinks will be linked to a specific area of the TV having an issue.
16helpful
The picture comes for 2 secs on the screen and immediately goes to stand by and red LED Sony bravia standby mode blinks 8 times
the picture comes for 2 secs on the screen and immediately goes to stand by and red LED Sony bravia standby mode blinks 8 times
2helpful
2answers
Sony bravia goes into standby mode blinks 13 times in sequence
standby light flashing is an indication that tv needs service. it prevents the tv from further damage. go to www.eservice.sony.com to check service options
Sony Bravia KDL-46Z4100 - tv turns off after being on for several minutes. turn off, back on and it continues to run for several minutes then goes blank again. Standby light flashes 12 times
Ur tv power supply board have dead parts call capacitors.U know basic electronic's and soldering?Take ur tv aparts,check the power supply board,that the board the power cord plug into it.Searches all around for these dead gas leakage capacitors,they all way bulges up on it top,or puff up on it top.Replaced these dead gas leakage capacitors,ur tv will have stable LED light and the power will work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
2helpful
Standby LED blinks 4 times
4 blinks on a Sony Bravia indicates a backlight/inverter (aka ballast) problem. These ballasts are regrettably only available with an entire LCD panel. :( You may perchance be able to find a parts outfitter online that scraps out TVs and have a used ballast.
Typical backlight problem on an LCD shows up as the screen lighting up for a second or two and going back off. The 4 blinks just confirms your problem.
13 red flashing standby lights tv turns on, then off
Seek professional serv technician. No listing for 13 fashes only up to 9.
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
