When controller says ready to start you must press display select button then hidden left button which you can feel as a raised
arrea under the membrane between the display select button and the orange ringed centre button. the screen should say checking machine a nd then ready to start if it has reset. if it comes up with line pressure then you must get back to ready to start and repeat method. this assumes the compressor has the SE Controller with green LCD screen
SOURCE: ingersoll Rand SSR compressor shuts down loaded or
When it shuts down, press DISPLAY SELECT button once and use the up down arrows to see the code just before shutdown.
HIGH AIREND TEMP
HIGH AIR PRESSURE
LOW SUMP PRESSURE
PRESSURE OR TEMP SENSOR FAIL
CHECK MOTOR ROTATION
MOTOR OVERLOAD
FAN MOTOR OVERLOAD
STARTER FAULT
I am assuming this has a Intellisys controller.
hello. i have problem alarm history address(register alarm,warning codes)for example 256-270 alarm code history please help
