Nokia 7210 Logo
Adnan Rasool Posted on Oct 02, 2013
When i connect my Nokia 7210 supernova with my PC via USB it shows usb device not recognized
John Darrelle Fulgar
Level 1:
New Friend:
Problem Solver:
  • Contributor 10 Answers
  • Posted on Oct 02, 2013
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
10
Questions
0
Helped
653
Points
30
Where did you plug it ? is it at the back usb port ?
Try plugging it at the back.
3 Related Answers
Anonymous
  • 1884 Answers
  • Posted on Jul 28, 2009
SOURCE: Nokia 6500 slide. Device Not Recognized
If you go to Control Panel -> System -> HardWare and check USB controllers which shud give you a list of all USB ports. Below that you will find Wireless Communication Devices. In this you shud find all the modes your phone is installed as. Check if all these settings are present. Secondly, install PC Suite now that you have restores the system to an earlier date. Connect the phone and connect.
Anonymous
  • Posted on Jul 05, 2009
SOURCE: i have nokia 7210 supernova with gprs work on pc but not at mobil
change ur apn addres to www.e.pr
Anonymous
  • Posted on Aug 24, 2009
SOURCE: i can't transfer datas from PC to nokia 7210
when i connect my 7210 via cable in pc suite it shows connect d cable,but in bluetooth it works fine.
Nokia 7210 supernova connected in a non compatible usb mode
nokia 7210 supernova. not connect pc suite and camera on standby why pls solve this and nothing play error not enough memory even hv memory
1helpful
2answers
In MY NOKIA 7210 SUPERNOVA MOBILE,MY PHONE DATA,LIKE GALLARY MENU AND CALCULATER GET DELETED,SO HOW I CAN RECOVER IT.
When you tried to reset or format your phone,your phone content such as calculator,wallpapers etc. will be erase. All you have to to is update the phone firmware using a Software .you also need a data.usb cable,full charge battery and a stable internet connection.
Here's how it works :
* First you need to download this software : NOKIA PC SUITE * install the software and run it after * turn ON the phone and plug the usb cable to your phone and thru the computer. * Some driver will be installing,wait until it is recognized. * Now follow step by step procedure until you need to start,be sure the above requirement follows. * wait until the process is done and now check your phone,all content you are looking for is their.
Jul 31, 2011 • Nokia 7210
3helpful
MOBILE: nokia supernova 7210 Sir, when I press 'GO TO' button and go to a special option my phone will be switched off, and if I press 'GO TO' button main Menu will not be opened with out switch offing...
Download Nokia Software Updater on Nokia's official website and install it in your PC. Connect it using a USB data cable and then update your firmware
Mar 28, 2011 • Nokia 7210
1helpful
From which website i download nokia 7210 supernova usb cable driver
Hi, lisanrose, you can download your Nokia 7210 supernova USB cable driver from here:
http://www.megaupload.com/?d=D7O6G0J0
36helpful
6answers
I'm forget my 7210 supernova security password. how can reset this password
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
OR:
Reset factory setting with nokia flasher box.
Thanks
Sep 07, 2010 • Nokia 7210
4helpful
I m trying to use my nokia 7210 supernova mobile as modem, with the help of nokia pc suit, but wen it is connected to pc, it shows that "no modem found", it also says that port driver is not installed,,,,
Hi, normally when connecting a phone to a PC with PC suite, you will need to install the drivers before installing the PC suit on your PC which is called Nokia Connectivity. It's a softeware that needs to be installed before the phone can be recognized on the system.
Use Google search and Type Nokia connectivity Download, after downloading, install and install the PC suite too. Then you can do what ever you want to do .
Take care.
Jun 15, 2010 • Nokia 7210
10helpful
I want to install symbian SIS file on nokia 7610 supernova mobile
you can install software or transfer files by connecting your device to a computer via a USB cable and use the Nokia PC suite to do it..download the software from internet to your computer(its free) and install them.
remember to download the exact version which suits your device as there are numerous types of pc suites.
thanks for contacting fixya!!!
2answers
I can't transfer datas from PC to nokia 7210
try to reinstall the software...sometimes taking it out and in again works.
Aug 16, 2009 • Nokia 7210
3helpful
Pc acess net frm nokia 7210supernova
For you to be able to connect to the internet using your nokia 7210 supernova as a modem, you must do the following;
1. First download the nokia PC Suite from Nokia site http://www.nokiausa.com/get-support-and-software/product-support, select your device, leave the accessory and move on to select the service & software"
2. You then move ahead to download and install the Nokia PC suite on your computer. After successful installation, please run it.
3. Double click on the icon for the nokia pc suite on your desktop, once it is running look for the button that has "connect to the internet", it is the green globe with 2 arrows on it.
4. Once you get that double clicked, it takes you to a pop up that would now enable ypu connect to the internet via your service provider. Click on configure on the lower end of that window.
5. Click on the modem that you'll be using for the connection (bluetooth, USB cable) and click next.
6. After that process you would then be prompted to select your network operator from the list, once you do that you can then click finish and allow it connect.
After some couple of minutes yu'll be connected to the internet using your phone as a modem.
Hope this helped.
Regards
Aug 04, 2009 • Nokia 7210
1helpful
2answers
Nokia 7210
you have to fit a bluetooth device to your pc..and then you can connect your phone to the pc via bluetooth..its very expensive..better but the CA-101 cable..its cheap and very easy and reliable
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
