Vacuums Logo
A
Anonymous Posted on Oct 02, 2013
The shampooer will not pick up the solution - Kirby Heritage II Vacuum
Marci Marple
Level 2:
  • Expert 357 Answers
  • Posted on Sep 15, 2014
Marci Marple
Expert
Level 2:
Answers
357
Questions
Helped
172237
Points
543
My shampooed won't pick up ythe water
does your shampooer have a cap on the shampoo tank. Usually you take the cap off to let the shampoo out while shampooing and to pick up the water you put the cap back on to create a vacuum to suck the water off the floor..
Jul 01, 2017 • Vacuums
2answers
Where do I get an adapter for my rainbow shampooer
This really depends on what Rainbow you have and which Aquamate you are using. There really is not an adapter for the Aquamate. The newest aquamate out there is for the E2 type 12 black that came out in 2012.
There is a modification of this aquamate to fit older E series vacuums (comes with a cord) , but you will need to have an electrified hose made for water pick up to use. You can find that aquamate here
Rainbow AquaMate 3 carpet shampooer
GoodVac
800-775-6586
Is there a pdf file that has the insructions for ultimate g series g shampooer
I don't know of any. But you can go to your local Kirby dealer and pick up a manual or DVD for under $10 bucks.
1helpful
What parts go to a Kirby Shampooer?
There is a shampooer head with shampooer brushroll, water tank, small hose that hooks to the tank, collection tray
Need to use the Kirby shampoo. It goes down as wet suds but you pick up the suds with the vacuum when it drys. Fill tank adding 1 cap full of soap (kirby soap only) per level on the side, this attaches on the side where the bag is attached
After using the shampooer you need to reattach the vacuum bag and main brushroll nozzle as though you were just vacuuming up dirt.
Instructions:
Lift the front of your kirby up (front part with light) open the handle on the dail in the front (if epquipt), remove the power head, put on height adjustment on highest level, turn dial on front of power head until you see 2 red arrows facing each other, unlock by turning knob, power head should come right off, get shampooer out the power head for shampooer with collection tray, make sure dial is set red on red, put on front of Kirby and lock in, turn dial to green on green arrows, fill tank adding 1 cap full of soap (Kirby soap only) per level on the side, this attaches on the side where the bag is attached, line up arrow and notch and turn, to hook up hose put Kirby down to lowest level, notched end of hose hooks in on tray other end on the tank,on/off switch refers to the foam, Turn machine on to lay the foam & scrub carpet, take shampooer back off to extract the foam once it's dry.
Good luck.
Shampooer won't pick up water
look on the vacuum where the suction is to pick up and you will see its clogged ,clean out the suction ports
2answers
My G series kirby carpet cleaner will not **** up the water or foam very well
The Kirby shampooer deposits the foam onto carpet,and works it into the carpet with the shampooer brushroll.After the carpet is dry,use the vacuum itself to pick up the dry foam and dirt.The Kirby Shampooer is not an extraction shampooer
How to put the double brushes back on the shampooer after cleaning them
I took the shampooer to a repair shop yesterday.. They had it ready to pick up the same afternoon.
Thank you for sending your reply.
How do I change my kirby g4 to sweep/mop mode?
Turn the belt lifter to red arrows matching to sweep the kitchen floor. This stops the brushroll from turning and allows you to use straight suction. There is a hard floor pad available...see the link to my guide and you may find one for sale...
As for mopping...I just dump a small bit of soapy water on the floor and run my Kirby shampooer (with no solution in the tank) on the lowest setting to scrub, then I dry mop behind it to pick up the excess water. There really are no instructions in the manual for scrubbing linoleum, but I just improvised. It splashes a bit, but better than getting down on hands and knees. Here is a guide to hook up the shampooer...
http://reviews.ebay.com/KIRBY-CARPET-SHAMPOOER-INSTRUCTIONS-MANUAL-DIRECTIONS_W0QQugidZ10000000004594992
Hope this helps a bit...
Marci
Top Kirby Vacuums Experts
Mike Cairns
Mike Cairns
Paul Bade
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
