If you could be more specific about your issue that what exactly you can see on screen or whether lights are turning on or not? In any case you need to check your power supply first using a voltmeter to ensure that out voltages are equal to mentioed rating or not and in this way you may need to try new charger,
SOURCE: keyboard driver
Hi
Sony normally make there own drivers, especially that it came with Vista, You will need to look for drivers on the sony website for the keyboard.
SOURCE: How to activate the Fn key in VAIO?
Press the FN function button, then on the function keys @ the top,
is a picture of a sun, up and down,
Hope this helps
Regards
Richard.
SOURCE: The FN key stopped working
Its probably just a broken key on the keyboard. If you know someone with a usb keyboard then plug it in and see if the FN key on that responds. if it does then it is the keyboard at fault.I would buy a new keyboard.
