Nikon Coolpix S4 Digital Camera Logo
Posted on Apr 21, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a nikon coolpix s4. I have used a Kodak sd 256mb memory card for years which has worked fine. I am going on a trip and wanted more memory and got a 4gb memory card. When I insert the card into the camera it reads "this card cannot be used." Why can't I use the card?
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Nikon Master 102,366 Answers
  • Posted on Jun 03, 2010
Nikon Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10442766
Points
622693
The S4 uses SD cards. Your 4GB card is actually an SDHC card and thus will not work in the S4. You will need to stay with cards 2GB and smaller.
SDHC 8GB memory card not working
The S4 works with SD cards, which max out at 2GB. It does not work with higher-capacity SDHC cards.
Will Nikon S4 digital camera take a Sandisk 8 GB HDHC card
No. The S4 works with SD cards, which max out at 2GB. It does not work with higher-capacity SDHC cards.
I have a 256MB compactflash memory card for the coolpix 4300 that was bought over 7 years ago. I went to Radio Shack and Walmart looking for another. The salesperson told me that the SandDisk 8GB...
According your camera specs listed on dpreview.com:
http://www.dpreview.com/reviews/specs/Nikon/nikon_cp4300.asp
your camera must support the FAT 32 file format in order to use a compact flash card that exceeds 2.2 Gb. I question whether a camera 7 years old supports an 8Mb card, but I haven't found any specific upper limit listed online anywhere.
Nikkon coolpix L1 After downloading memory card .. then putting back into camera. Reading says "cannot read memory card." Checked card out at store verified that it is good. Why does it not work in my...
A couple things you might try.. remove the card carefully and check the position of the "lock" tab. Make sure it is fully in the unlocked position - not locked or a point between the two positions. Reinsert and try again.
It sounds lie you're using a card reader to download the pictures - try formatting the card while in the card reader via computer. The card should be completely empty when the format is complete. You can even try copying files to and from the card to make sure its ok and format again. When complete, try again in camera.
If the problem persists, check to make sure the card is on Nikon approved memory card list for use with the Coolpix L1 (provided below):
The following is a list of approved memory cards for the Coolpix L1 digital still camera. These cards have been tested and approved for use with the Coolpix L1.
The L1 uses SD (Secure Digital) memory. Sandisk:
  • 64MB, 128 MB, 256MB, 512MB, 1 GB, 256MB*, 512MB*, 1GB*
Toshiba:
  • 64MB, 128MB, 256MB, 512MB, 1 GB, 128 MB*, 256MB*, 512MB
Panasonic:
  • 64MB, 128MB, 256MB, 1 GB, 256MB*, 512MB*, 1GB*
* - Cards rated for 10MB/s (high speed) Other cards have not been tested. For more details on the memory cards listed above, please contact the manufacturer.
The list came direct from Nikon Support. Other cards may work, but only those on the list are approved. Successful use of other cards can not be guaranteed.
I hope this helps!
MEMORY CARD
Hi there.
This may be easier than you think.<grin>
SD cards can become accidentally locked. Double check your card. Take a look at the side of it. There will be a little switch. Make sure the switch is in the unlocked postion and see if that's your problem. Let me know if that doesn't help.
Rob
1helpful
Sd memory card cannot be used
This happenes when you remove the card while read/write process is still going on. Try some professional service who will retive the data for you from the mem card. Hope this helps.
1helpful
No memory card will work in my Coolpix camera
Nikon has tested the following cards and approved their use in the Coolpix 3200:
SD memory cards:
SanDisk 16/32/64/128/256MB
Panasonic 16/32/64/128/256/512
Toshiba 16/32/64/128/256MB
Other brands and capacities of cards may work, but Nikon cannot guarantee their operation. Check with the manufacturer of the third-party card for compatibility information. Nikon recommends keeping one of the approved cards available for troubleshooting.
Multi Media cards (MMC) are not recommended and should not be used.
2helpful
Card Cannot Be Used message?
If you've been using a 512mb sd card and it's worked your extremely lucky. the support was only designed to go to 256mb
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
