My USB flash drive was infected by trojan horse (autorun-EL[trj]) what should i do to delete this thing.!!
Too complicated for this type of forum. Go HERE, register and post in the Malicious Code/Virus section. A tech will be along to help you. Read the instructions for posting and follow them when you post, it will save a lot of time.
SOURCE: virus infection
you have to stop Autorun feature of your
windows which kicks in when we connect any new storage device first,
then you will be able to format the drive and start fresh.
Steps to remove autorun:
http://support.microsoft.com/kb/967715
(restart your computer first without the pen drive and then start the below procedure)
SOURCE: how 2 delete file autorun in my system without appearing in futur
When your computer automatically creates a "autorun.inf" or "autorun.exe" file on your pen drive, you have a virus. This is the way it multiplies itself in order to infect other computers. First, do a virus check and disinfection procedure on your computer (use a strong antivirus, like Kaspersky - they have 30-day free trial). After that, plug in the device, and now try to format it. It should work, if your computer is not too affected.
SOURCE: Hellowhen i plug my sondy memory stick pro duo 4gb
You are trying to acess the part of the mem stick that is locked. Acess it via My Computer instead.
SOURCE: usb flash drive showing shortcuts inside, help me,
Is this the Problem???
Only Shortcuts,,,,,,
Don't format your Flash Drive.
Your data is still there.
Use Shortcut Virus Remover.
It will recover your all data.
DOWNLOAD !!!
http://shortcutvirusremover.blogspot.com
VIRUS OR TROJAN INFECTIONS:
Virus or trojans can run some process that keeps running in background. This not only harms the computer, but also prevents the pen drive from formatting as it shows that the drive is in use. Remove and re-insert thepen drive, don't double click on drive and cancel autorun operations if it starts automatically. Run a virus scan on pen drive, this will help fix the issue. Now format the pen drive.
Always take precautions while using pen drives on other computers. See the some of our posts below on protecting your pen drive from viruses:
CORRUPTED FLASH CHIPS ON PEN DRIVE:
If the pen drive is not detected at all, or shows a less capacity, then there are high chances that its a chip corruption. Flash chips are the actual hardware components that save the data. A physical or electrical or electromagnetic damage to these chips make the pen drive faulty. This can happen because of voltage fluctuations and faulty USB ports. In such case, get the flash drive replaced if its under warranty as it can not be fixed otherwise.
FAKE PEN DRIVES:
Sounds a bit un-believable but true. There are a lot of pen drives in the market which are of very cheap quality which are fake copies of some known brands. Beware of such pen-drives. Always purchase pen-drives or memory-cards from a reliable source with bill and warranty to avoid any mess later.
