Question about Husqvarna Craftsman 36cc, 16 In. Gas Chain Saw
How to repairor replace small gas line on craftsman chainsaw model 358.360260
    Scholar:
    New Friend:
  • 43 Answers
Before you begin, make a mental note or take a picture of how the fuel line runs from the tank to the carburetor so you will be able to put the replacement in the same position.
On most chainsaws you need to take some wire, make a u-shaped end, which will be used to grab the fuel filter in the fuel tank. Drain the fuel in the tank. Disconnect the fuel line from the carburetor. Generally there are two lines on the carburetor, one for fuel, the other line creates suction used to pump fuel and is connected to the motor, not the fuel tank . Just disconnect the fuel line, it is usually on the side of the carburetor and will leak gas when disconnected. Once this is done, using the wire, gently grab and pull the filter towards the filler opening and using needle nose pliers grab the fuel line above the filter and pull. The problem you may have, is if the fuel line is in bad shape it will break, But once you have the filter off the fuel line, the fuel line can be pulled out from either the inside of the tank or from where it comes out of the tank and goes to the carburetor. Once it is removed you are ready to put the new fuel line in.
It is best to put the fuel filter on the fuel line next. It easier than trying to put it on inside of fuel tank going out. Spray some WD40 or equivalent, on the outside of the gas line, to help the line squeeze through the whole in the back of the tank, which it will have the go through. From the outside of the tank, where the fuel line comes out, fish some wire inside the tank and put the fuel line on the end of it, making sure not to pierce or damage the fuel line. If needed a piece of black tape will hold the wire better and help fit the line through outside hole. Once the fuel line is on the wire, pull it through carefully out the other side of the tank. It is best to use your fingers to pull the line through the outside hole, it makes it less likely the line will get torn or overstretched as line goes through the hole because of the extra rubber used on the line to seal the tank from inside and outside. Once the line is pulled through and seated, run the other end to the carburetor and you are done.
Posted on Oct 02, 2013
4 Suggested Answers
6ya staff
SOURCE:
dontbother10
dontbother10
  • 2220 Answers
SOURCE: Diagram of fuel line for Craftsman 16" chainsaw
Your saw is a Poulan. Try converting the cc to a model number. A 2.2cc Craftsman is often a Poulan model 2200. go to this link and find something that appears the same under (POULAN-WEED-EATER).
http://www.ordertree.com/cms/illustrated-parts-list/9788.html
The IPL will help. Pay attention to the year there is a different area for older saws.
For a current saw Craftsman should have something available.
Posted on Sep 04, 2009
Eric Schultz
  • 70 Answers
SOURCE: 16" craftsman chainsaw primer pfoblem
Check the condition of the fuel line and filter in the tank and to the carb and primer.Today gas and time will soften them allowing them to become blocked or leak.Replace if needed.
Posted on Oct 24, 2009
dontbother10
dontbother10
  • 2220 Answers
SOURCE: Replacing 16
The second carburetor port feeds the primer (bleeder), returns excess fuel to tank.
Filtered line to carb, carb to bleeder, bleeder to tank (probably not visible and no hose in tank).
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
You can find an exploded parts list wit a little detail here:
http://www.searspartsdirect.com/partsdirect/index.action?psid=74199074&sid=PSx20071217x00001a&OVMTC=Exact&site=&creative=3873724584&OVKEY=searspartsdirect%20com
The print is deceptive, it appears the filtered line feed the bleeder it does not!
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Posted on Apr 18, 2010
Fuel Lines - 25cc Craftman weedwacker
Your Craftsman Trimmer/weedwacker:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=358795591+&pathTaken=partSearch
Best Poulan Engine Match (probably real manufacturer):
http://www.ordertree.com/modelinfo/PWE/BC2400-Gas-Trimmer-Type-6/75.BC2400-Gas-Trimmer-Type-6.1.59.1.html
My decisions are being driven by my experience with Poulan chainsaws. Small hose in tank (long enough to reach all corners), filter on bottom, connects to lowest connection on carburetor. Small hose on upper carburetor connection to small fitting on primer. Large hose from large connection on primer through largest tank hole, roughly mid tank long. nothing on bottom. I suggest you leave the 2 connections on the carburetor long enough they can be swapped (just in case) then try it. if no go swap them.
Typical fuel system and a suggestion or two:
This is how I would configure it if a chainsaw, doubtful they would do something completely different. In defense of Jerry, he knows how it should be done, clarity of instruction could use some help. Good Luck. HTH
Lou
Feb 24, 2010 | Craftsman 25cc Gas Line Trimmer
The gas lines on my craftsman chainsaw rotted so i am replacing them but i dont know which goes where
A typical fuel system and a couple of suggestions can be found here:
You can likely find an IPL for your saw here: The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best; components are listed but may be on different illustrations.
http://www.searspartsdirect.com/partsdirect/index.action?psid=26128416&sid=PSx20071217x00001a&OVMTC=Broad&site=&creative=3268989744&OVKEY=craftsman%20parts
Almost all Craftsman chainsaws are made by Poulan. If you provide the engine and bar size I can almost certainly provide a link to the applicable Poulan IPB.
Fuel line can be obtained at any local chainsaw outlet. 12” of any different sizes is probably ample but inquire within. I recommend you take a small sample of each different size.
You can reply below with the numbers or any questions you may have. I hope you found this most helpful.
Lou
Jan 31, 2010 | Garden
Sears model 358.356280 chainsaw. Just replaced
Sounds like you need to pull out the spark plug and put some fuel directly into the cylinder to get it fired up.
Nov 14, 2009 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Oct 24, 2009 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Sep 04, 2009 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Gas mix
ok buy the cheap gasit does not need the high price stuff 1 gallon of gas and 1 small bottle of two cycle oil. thats all you need
May 24, 2009 | Craftsman 25cc Gas Line Trimmer
Need diagram for fuel lines on craftsman chainsaw
There is two sizes of line. I see the large one goes to the large port on the primer button and then to the fuel tank. The small one goes from the primer button to the carb. The problem is there are two hose connections on the carb. I believe one is a vent, but I am not sure what one it is. I have a 36cc 2-cycle model 358.352161
Feb 27, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Husqvarna Craftsman 36cc, 16 In. Gas Chain Saw Logo
77 people viewed this question
Top Husqvarna Garden Experts
J. Bradshaw
Marvin
Marvin
dannydoesita
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
