Ok i moved to another location in town.
my player will record but it fuzzy on play back.
the tv vcr swith shows tv but when play back occours it fuzzy.
Ive never really seen crossbanding since we all went digital.if u have option (you should)just turn rf output off im assuming u are on digitaltv anologue would mean your move has meant different transmitter and a retune would be the answer
MOST LIKELY the RF out put signal is the same as a local tv chanel 1) try menue change rf output suggest rf 68! OR connect av leads (red white yellow)from the output of your vcr and connect the other end to an Av input eg AV1 on your TV use tv remote to select the AV input
