This is happening to my stairmaster 4000pt. I'm not sure if it is the console or something else. Any solutions for this specific problem? The posted answer was not very specific to this issue.
Follow this steps and fix it. God bless you
Plug it in. The first troubleshooting step is always the
most obvious. Your elliptical machine needs to be plugged in for the
console to work. Ensure that the plug is securely placed into a grounded
outlet and that the outlet is receiving power. Check that the circuit
breaker has not been tripped.
Sponsored Links
www.kendoui.com/framework
Calibrate the ramp. If the ramp is not positioned correctly,
it could need to be calibrated. Often this is done from the console.
How you calibrate the ramp is dependent on the make and model of the
machine. Refer to the owner's manual or customer service section of the
manufacturer's website to find out how to reach the calibration settings
on your specific machine. Many companies offer manuals in PDF format
for download on their websites.
Adjust the drive belt. Again, your specific make and model
of machine will determine how you do this. Usually, you'll need to
unplug the machine and locate the drive belt area. This is often beneath
the panel housing the wheel and pulley. You may need to find a release
latch or use a screwdriver to remove this cover. Refer to the owner's
manual for your model to make sure you do not damage your machine.
Read more: http://www.ehow.com/how_6737713_troubleshoot-elliptical-problems.html#ixzz2gWAdfrgF
