Follow this steps and fix it. GOD BLESS YOU
Lid Switch
This is the most common reason for the washer not spinning or agitating.
This is easy to check. You will need to remove the switch, this varies
with model type but the testing will be the same. When the lid is closed
the switch should have continuity when the lid is opend the switch
should have no continuity. If it differs replace it.
Timer
To check the timer you will need to refer to the wiring diagram or
disassemble to access the motor. Check the leads from the timer to the
motor when turned to a wash cycle this should have 120 volts. If not replace it , if it does the timer is not the problem.
Motor
To check the motor you will need to disassemble the washer
to access the motor. First you can check the motor windings, to do this
remove the plug and connect ohmeter to terminals. Refer to the tech
sheet or service manual for the proper reading. Check motor for shorts
by connecting ohmeter to terminals and motor housing should have no
continuity. Connect voltmeter to motor wire connector and check for
voltage. You should have 120 volts, if you do and the motor does not run
replace the motor. If it does not have power the problem is elsewhere.
Belt
If your washer is a belt drive type make sure the belt is tight. Check
for black soot from belt wear. Replace if it has excessive wear or
broke.
Motor Coupler
This is a fairly common problem with direct drive machines but
inexpensive and easy to replace. The Motor Coupler transfers power from
the motor to the transmission. The following video will walk you through
the replace it
Transmission
The transmission does not usually fail. To check this on a direct drive remove the motor
and then turn tub inside. If it spins freely with no noise the problem
is elsewhere. If it is noisy it needs replacing this is expensive and
depending on the age of your machine you may not want to replace it. On a
belt drive remove the belts and spin tub.
SOURCE: ge washer
I just had the same type of problem and fixed it. The door switch under the lid is not working properly. Mine wasn't working because some lint, etc. got caught around the switch wiring and as the agitator used to spin, it spun a knot around these wires. Over time, this knot started to pull on the wires and one of the wires got disconnected. So, for the time being, I "jumpered" the switch out and can operate that way. BUT, THE SPIN CYCLE WILL CONTINUE TO WORK UNTIL YOU SHUT IT OFF. IT WILL NOT SHUT OFF BY ITSELF (AUTOMATICALLY). ALSO, BE VERY CAREFUL. THE DOOR SWITCH NOW DOESN'T WORK UNTIL YOU WIRE IT BACK IN. THEREFORE, THE SPIN CYCLE WILL CONTINUE UNTIL YOU SHUT IT OFF YOURSELF (NO DOOR SWITCH IN OTHERWORDS).
Good Luck!
SOURCE: My GE washer #WDSR2080DEWW washer
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
SOURCE: GE Adora front load washer turns until water is added then won't turn or spin
You should contact GE or qualified appliance repair center to be looked at professionally.
