SOURCE: SD card reader
Is the SD reader built in? If so, you should just be able to insert the SD card into the slot, and it should appear in My Computer.
SOURCE: SD Card Reader Not Working on Acer Aspire 5600 Laptop
Your card reader on your computer isn't capable of reading SDHC cards. You have to use a card reader approved for SDHC use.
SOURCE: SD card reader not recognizing card
the original file (apparently version 2.0) is here:
http://64.233.161.104/search?q=cache:2288as3q0skJ:www.asus.it/support/download/selectftp.aspx%3Fl1_id%3D3%26l2_id%3D45%26l3_id%3D0%26m_id%3D1%26f_name%3DCardReader_050118.zip~zaqwedc+CardReader_050118.zip&hl=en
the updated driver (version 2.3) is located here:
http://support.asus.com/download/download.aspx?modelname=V6V&SLanguage=de-de
scroll down to where you see RICOH card reader driver
or more specifically this link here:
http://dlsvr03.asus.com/pub/ASUS/nb/V6V/CardReader_XP_2K_050808.zip
even though the site is primarily in german, all the component names are in english, go figure. So it would seem that the asus comp manufacturer are a little more forthcoming than dell in this particular instance. for example, nowhere on my component sheet does it say that RICOH is the manufacturer for the card reader, that's something i got from you guys on the forums
anyway, after installing this driver and rebooting my comp, card reader immediately recognized both MMC and SD media. unfortunately, it was only able to access the mmc card, and i'll be shipping my comp off to dell for whatever motherboard replacement they're willing to give me (which i don't mind, so long as it works when it comes back to me) but i thought these links might be helpful for others who are having the same problem.
SOURCE: need a driver for my card reader
YOU CAN FIND THE DRIVER FREELY THROUGH SOFTPEDIA OR WARESEEKER WEBSITE IN DRIVER SECTION
What happens when you tried to plug-in SD card to the computer?
Have you made any recent changes to the computer prior to the issue?
To make the SDHC be recognized by the computer, we need to ensure that the card reader works in Windows 7 first. Please check if the card reader is recognized properly by the computer and you have installed the driver for it.
Meanwhile, you can plug some other storage cards to the card reader and see how it works.
I would suggest you to refer the link below
A Secure Digital (SD) card may not be recognized on a Windows 7 based computer.
http://support.microsoft.com/kb/981642
Uninstall all the Generic USB drivers and reinstall.
1. Open Device Manager.
2. In "Disk Drives" dropdown, uninstall the "Generic SD/MMC USB device" drive.
3. Restart computer.
4. Insert SDHC card.
Hope this helps.
Hope this helps.
