Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
Posted on Sep 21, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Reloading XP2 sir...I am using XP sp2.when i turn on the system it loads os,but instead of welcome screen it automatically restarts from begining for 2or3 times and then desktop appears.the problem is while loading OS.for this I formated my system 8or 9times of different cds&versions,But the same problem repeats.Someone said that it may be Harddisk problem.Is it true...?.please solve my problem. thank you
  • 1 more comment
  • sreeharinsp Sep 21, 2007
    Please solve my problem
    ccc
    thank u fr giving suggestiond.I cleaned the memory(RAM) and again I put it.But the sam problem is occuring asusually
Anonymous
Level 2:
  • Expert 59 Answers
  • Posted on Sep 21, 2007
Anonymous
Expert
Level 2:
Answers
59
Questions
0
Helped
36876
Points
104
My opinion is hard drive has faulty sector and possibly an increasing number of them. If it's under warranty I would have the HDD replaced. If not under warranty you can try to go to the HDD manufacturers site and download the HDD utility software. There will be a low level format utility. This will mark bad sectors during the format process, if you keep getting more bad sectors when you try to reload OS your drive is toast...toast...toast... -Good luck
Simon Clarke
Level 1:
  • Contributor 57 Answers
Simon Clarke
Contributor
Level 1:
Answers
57
Questions
Helped
20365
Points
90
After you test the memory, you should test your hard drive with a utility downloaded from the manufacturer's website. DFT from Hitachi works with other drives also http://www.hitachigst.com/hdd/support/download.htm#DFT If you press F8 repeatedly while the computer is booting you should get an option to disable automatic restart. This should then leave you with a blue screen error message which may provide more information. Did you instal the operating system while the computer was connected to the internet?
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 293 Answers
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
293
Questions
0
Helped
248405
Points
718
MEMORY PROBLEMS Hi, FOR LONG BEEPS, ONE SHORT BEEP IN AN ENDLESS LOOP, BLUE SCREEN OF DEATH AT STARTUP Try using Memtest 86+ http://www.memtest86.com/ to diagnose your memory problem. You can also try the following methods. Turn off power, Unplug. Remove the cover of your PC. Remove the memory from the Motherboard. Note on the locks! Clean the memory contacts with an eraser yes that's right a rubber Pencil eraser. It should be shiny gold. Reseat your memory to the motherboard and Test! POWER SUPPLY try replacing both your hard disk and / or power supply ====================== If you are having trouble with Newly bought items save your self from headaches by returning them and demand a replacement or a refund! You may have purchased a reconditioned\repaired\factory defect product.
What make installation this nero 7
Yes. We have used it many times with Windows XP SP2 (I assume by XP2 you mean XP SP2.
My laptop running in win xp home edition sp3 does not boot. it only shows the options to run in safe mode, etc...Last known good configuration... how do i solve this? it doesnt boot.
Try to buy a Windows XP2 cd . The cd key is ( HH8M2 - JV8XT - PGWY2 - 8WV28 - 2B9M3 ). Replace your old OS xp home edition , with Windows XP2 OS. Hoping this would solve your problem sir. Have a nice day..
Ask for geniune microsoft software
Dear Sir,
Favorably, to a date before microsoft installed this together with an update.
Then don't install this a MS Spyware again!
But wait, If you are using a genuine MS operating system there's no reason to remove this slight annoyance...
Buy a legit OS or try Linux instead to avoid further problems...
Thaanks For Your TIme
Sir as i m installing xp2 pack as os within a week i m getting a system 32 error nd a blue screen error where the system gets restarted and a message appears stating the ''THE WINDOWS DELAY WRITE...
run a hard disk self test from the bios.....if it fails then you have to replace your hdd and if it passes then reinstall the OS from another disc
How to instal xp2 in dell laptop
try this!
if you have a xp2 bootable cd,..insert it on your cd-drive
step1: power on your laptop , then press dell until you view the bios set.up
step2: then go to boot sequence: your first boot is your ( cd-drive ) where your cd xp2 is in....
note: in boot sequence just follow the reference of your laptop settings...
step3: if you finish seting up the bios set.up,..just save and quit...then it will automatically restart...then wait for instructions view on your screen...
XP RESTARTS
this is caused because a file of your pc has become corrupt and your XP needs to be reinstalled.
3answers
Compaq presario 773tu external speakers problem
You may have to download a different audio driver for your Vista OS.
2answers
Xp sp2
hi,
Try this,
Right click on my computer then go into the properties, on top theirs a tab called advanced, click on it. under Advanced tab their should be 3 options, 1 should called start Start up and recovery, click on its setting, then uncheck the box called Automatically restart. click OK, OK. restart the computer this should do the job.
hope this little info helps.
TY
1helpful
3answers
Not Installing XP SP3 Updates Given By Microsoft KB 936929.
if you don't want to install those updates you should have switch off your automatic updates. the problem is the your computer might not be compaitble with the update which was sent to you.XP SP3 have a higher system and hardware requirements than xp sp2. in order to resolve your problem you need to run your xp sp2 and press repair instead of format in this way it can return to your original system. you can also try the system restore press the start, all programs look for the system tools then system restore check what date you installed this sp3 then select the day before you installed this in order for you to return to your original operating system. hoping that this will help you, expecting your positive response.
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
