Check the condenser coil to make sure it is cleaned out, also make sure the condenser fan is no dropping out. Next check to make sure the water fill valve is not seeping water past into the sump tray if so than it will not freeze, Water will get cold but not cold enough to freeze check water temp in sump tray with a thermometer to make sure it is getting down to 32 deg.
