First check spark while cranking over( pull the plug wire hold by insulator about a 1/4 inch away from any ground, you should see a strong spark. then check to be sure the fuel is pumping from yhe carb., if no fuel try a short squirt into the carb intake. should fire up if you had spark.Its generally a good idea to put in a new plug and be sure to check the gap.
