SOURCE: i have a F &
56. (00111000) Phase 4 to 6 - Basket Check No Valid Fault While carrying out a basket check, the machine has not been able to determine a valid tub status and so the Display flags this fault. This fault differs from fault 40 in that a valid tub status could not be determined. The first two areas to check are the clutch and pressure tube. If these two appear correct, then the fault could be with the pressure transducer in the motor controller. Primary Source: Mechanical. Action: 1) Check that there are no clothes or other foreign objects preventing the clutch from re-engaging. 2) Next check that the pressure tube has not come off and that it is not kinked. Secondary Source: Motor Controller module. (Phase 4) Rotor Position Sensor (Phase 5 and 6) Action: Replace the Motor Controller module. (Phase 4) Rotor Position Sensor (Phase 5
and 6)
Action:
from re-engaging.
Action:
and 6)
