My Santa Fe compact dehumidifier in my crawlspace makes a noise (not a smooth humming sound but more of a harsh vibrating sound) when it is not dehumidifying. I can turn the knob to the dryest setting and...
The black cylinder is the compressor. It sounds like your unit is cycling the compressor for some reason. If the compressor starts, runs fine, and removes water when you set the humidity control to the driest setting the compressor is probably OK and the problem may be with the humidity control causing the dehumidifier to "short cycle" for some reason. You may need to change the humidity control or relocate the dehumidifier in your crawl space.
If the compressor attempts to start, and then sits quiet for 10 minutes, and then attempts to start again, you have a problem with the dehumidifier. There are a few things that can cause this problem:
Low refrigerant charge
Bad compressor capacitor
Bad compressor overload
Plugged capillary tube or broken expansion valve
are the common causes of this behavior. If you suspect one of these problems, call the factory service department at 1-800-533-7533 for help.
Good luck with your dehumidiifer.
