SOURCE: Washer agitates, but makes horrible grinding noise. Spins okay.
thanks for posting problem solve :0)
SOURCE: ge washer not draining or spinning
Washer will not drain or spin. Got the water out andf tried it . It would spin and seem to drain what little was left in the drum. When I added about 1" of water it would not drian or spin. Drum sets at an angle also.
SOURCE: Final Spin Drum BANGS around--terribly frightening noise!
Check the spring that hold the drum in place. They are about 4-5 inches long on the top of the drum at about 2 and 10 o'clock. The springs suspend the drum and if broken the drum will bang around. About $40 to order springs online
Also check on the bottom at about 4 and and 7 o'clock because there are 2 shock absorbers that help keep the drum from just bouncing and bouncing with no end in sight. Again about $40 to change each one.
I am in the process of the first repair and doesn't seem too difficult. The second was done about 6 months ago and was not too difficult but was awkward because you had to lay on the floor to get the replacement pins in place.
SOURCE: Walking during the spin cycle
My GE front load washer model WCVH6800JBB have the same problem. I just purchased and installed it yesterday, 05/04/09. Just like everyone said... when it got to the spinning cycle it walked to the middle of my garage and all the connections in the back of the machine fell off. My husband checked the instruction... There are 4 nut bolts in the back of the machine near the rubber leg (level). You need to take them off and try to balance your machine again. My washer is running very smooth now. Good luck!
