Krups 240 Watts 8008 3 Mix Combi Hand/Stand Mixer Logo
A
Anonymous Posted on Sep 29, 2013
Krups ka902 how do i replace drive belt - Krups 240 Watts 8008 3 Mix Combi Hand/Stand Mixer
How to replace the drive belt on a Bodum Stand Mixer 11381 and where do I get a belt for this machine in New Zealand?
Contact them direct. No one sells them online.
Or most cities have a drive belt supplier. Take in the old one and say 'can I get one of these'. There are 8 places near me!
https://www.google.com/search?q=drive+belt+suppliers+near+me
Food Mixer BISTRO Black - Kitchen Appliances
Bodum https://www.bodum.com > 11381-01us-3-bistro
The food mixer BISTRO Black has a 7 speed motor up to twice the power of traditional stand mixers. Its attachments are also dishwasher safe. Bake in style!
US$103.99
https://www.google.com/search?q=Bodum+Stand+Mixer+11381+belt
Dec 17, 2023 • Food Mixers
2answers
Kenwood Chef Premier can run at all speeds for the first few seconds. Then it runs slower and you can tell by the sound.
It sounds like there may be an issue with the motor in your Kenwood Chef Premier mixer. This could be caused by a variety of factors, such as a malfunctioning motor, a problem with the drive belt or gears, or an issue with the electrical components of the mixer. To troubleshoot the problem, you may want to try cleaning and lubricating the drive belt and gears, as well as checking the electrical connections and fuses.
My Mix3 4004 Krups hand mixer stopped working a long time ago. I replaced the capacitors...but now I don't know where to start checking
Krups produce a premium product and it would be surprising if they didn't also have a repair or exchange service. Sometimes such a service is a reasonable cost and it is advisable to at least make the enquiry before proceeding further with your home repair.
Early food mixers used a number of series resistors for speed control and the circuit was fairly straightforward to check with a multimeter and any capacitors found are likely to be radio interference suppressors.
Later mixers use an electronic speed control and the best mixers use feedback to maintain the speed and torque when mixing or beating viscous material that would otherwise slow the speed significantly.
Checking/troubleshooting the electronics are beyond the scope of home repair, however, the circuit can be checked to the speed control fairly simply and then from the speed control to the motor and the motor itself. If everything else checks out then it would be reasonable to assume the electronic speed control has failed.
Early electronic speed control used either a thyristor as the control device or a diac/triac pair mounted on a small circuit board. Later types probably use a speed control module similar in principle to those found in power drills...
Drive belts and driving sprocket
Patent US4832502 - Agitation supporting and ... - Google
https://www.google.ch/patents/US4832502
GoogleMeans for supporting and driving agitators in commercial food mixers and the like ...Agitator means according to claim 1, wherein said drive belt has a tapered cross .... 1, 2 and 4) which is coupled to a bowl-tilt shaft 42 by a drive chain 44 and ...
www.google.com/patents/US4832502 GoogleMay 23, 1989 - Agitation supporting and driving means for commercial food mixersand the like ... said agitator driving shaft, and wherein said drive belt extends between.... of the drive chain in the area adjacent the mixing bowl and agitators,
Robotic Mechanisms - PULLEYS and BELTS 51045 ...
www.robotpark.com/.../robotic-mechanisms-pulleys-and-belts-51045/
Jul 17, 2013 - A large drive pulley driving a smaller driven pulley by means of a belt or.... bikes, agricultural machinery, food mixers, washing machines, lawn mowers, etc. ...Chain Drive System: A system consisting of a chain and sprockets ...
Feb 03, 2016 • Food Mixers
1helpful
Krups ka950 food mixer no speed control always top speed
The speed selector circuit has been compromised but either an electrical short, or disruption from particles that entered the switching mechanism and covered contacts. Needs technical attention.
Blender attachment does not work
It could be the drive belts. There are three. One for the motor to the belt drive. one from belt drive to bowl mixer spindle. one from belt drive to mixer spindle. mine started to do the same thing. I ordered the belts from Bosch.
2answers
Will not spin dry
If your washer won't spin, check these:
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Thanks for contacting Fixya.com
Top Krups Food Mixers Experts
ADMIN Andrew
ADMIN Andrew
john h
ADMIN Eric
ADMIN Eric
Are you a Krups Food Mixer Expert? Answer questions, earn points and help others
