CureUV Zund UVjet 215-C Compatible Digital Printer UV Lamp VZero 085D Logo
Eddy Van der Heide Posted on Sep 29, 2013
I got a Zund 215-C UV Flatbed printer. Unfortunately There is no documentation. Does anyone have manual / service manual or know a source where to get it? The machine needs some maintenance but I'm afraid without documentation this is not doable. thanks in advance.
wommelstee
Level 1:
  • Contributor 2 Answers
  • Posted on Jan 06, 2014
wommelstee
Contributor
Level 1:
Answers
Questions
0
Helped
339
Points
Cannot source replacement handwheel , can anyone help me source one
Have you tried http://www.sewingpartsonline.com/handwheel-viking-4123009-01.aspx ?
Does the N122OU have OCR capability?
OCR can work on any Scanner, I Believe that the Software is what converts to OCR. I Have A CanoScan N659U. Using Microsoft Office Document Imaging software scanned 150 sheets of genealogy that I do not have to retype. OCR has been around sense about 1928 however, not until about 1974 was the principal used with Flatbed scanners. They do have a few Open source OCR scanning software's available, and they have serval online OCR services. I Prefer the MicroSoft Office 2007 Document Imaging Software myself.
2helpful
Energy consumption of 1.5T LG intelloair split A/C
your energy consumption will be the exact same the capacitior does nothing to alter your systems operation. a capacitior is a voltage absorbing unit that provides ample power for a mechanical device when it starts. the only way to lower your energy consumption from the largest appliance in your home is to buy a more efficent one with a high SEER or EER rating.
1helpful
The text of a document will not print. The
Print From Your Computer : Windows Printing Select Basic Options Click the Main tab on the top of the printer settings window to select your basic print options. 1. Select a Quality Option that matches your document or photo, and the print quality you want. Quality Option settings WebWorks_WriteArrow(WebWorksRootPath, "wwdd1032347", false); WebWorks_WriteDIVOpen("wwdd1032347", false); • Draft: for rough drafts with reduced quality • Text: for documents containing only text • Text & Image: for documents with text and images • Photo: for photos and graphics with good quality and print speed • Best Photo: for photos or graphics with high print quality WebWorks_WriteDIVClose(); 2. Select the paper Type setting that matches the paper you loaded. 3. Select the paper Size setting for the paper you loaded. Paper size settings WebWorks_WriteArrow(WebWorksRootPath, "wwdd1032380", false); WebWorks_WriteDIVOpen("wwdd1032380", false); You can load paper in these sizes and select the size in the printer software. (Wider papers are for use only when reducing large images with the Reduce/Enlarge Document option.) A User Defined option is also available so you can create a custom size. A4 (8.3 × 11.7 inches) A6 (4.1 × 5.8 inches) Letter (8.5 × 11 inches) Legal (8.5 × 14 inches) Half Letter (5.5 × 8.5 inches) 3.5 × 5 inches 4 × 6 inches 5 × 7 inches 8 × 10 inches 16:9 wide (4 × 7.11 inches) Envelope #10 (4 1/8 × 9 1/2 inches) WebWorks_WriteDIVClose(); 4. If you’re printing borderless photos, click the Borderless checkbox. For documents or photos with borders, select Borders. Note:
For borderless photos, make sure you loaded a compatible borderless paper size and type. 5. Choose Portrait or Landscape orientation for your document or photo. You can also: • Select Print Options Select Basic Options Click the Main tab on the top of the printer settings window to select your basic print options. Select graphics & text. USER'S MANUAL EPSON WEBSITE: http://files.support.epson.com/htmldocs/cx44__/cx44__ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Borderless printing kodak 5500, clear coating business cards
Go to printing preferences of the particular program and then select Borderless . THESE ARE THE SIZE OF PAPERS SUPPORTED IN Kodak printers.
  • 3½ × 5 in.
  • 4 × 6 in.
  • 4 × 8 in.
  • 4 × 12 in.
  • 5 × 7 in.
  • 6 × 9 in.
  • 8 × 10 in.
  • A
  • A4
2helpful
3answers
Manual
i need a manual for my Husqvarna 215 sewing machine.
can you help me?
Adf for Ricoh IS100E
According to the manual, the part number for the ADF Document Assembly is VRC70001, but you may want to verify this with Ricoh before ordering, because the assembly is not shown in the parts diagram, only listed in the chart.
Hope that helps.
2answers
Looking for a canon f50 multipass reference manual. Reason: trying to use flatbed scanner to scan - not the automatic document feeder. automatic document feeder works. The article I wish to scan does not...
To scan from the platen glass:
1. Click the "Setting" icon on the multipass toolbar
2. Select "Toolbar Settings" tab
3.Under "Image Source", click the "Scan From" drop-down menu and select "Platen"
Top CureUV Office Equipment & Supplies Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a CureUV Office Equipment and Supply Expert? Answer questions, earn points and help others
