While opening or working with an application, it is quite common for an error to occur. If you're encountering the QuickBooks unrecoverable error, then you're not alone. This error has been encountered by many QuickBooks users and they have fixed it using simple troubleshooting instructions. Generally, when QuickBooks encounter this issue, you will receive an error code. Follow 3 simple methods given here to fix the error. https://installation-help.com/quickbooks-unrecoverable-error/
I had a similar problem a while back. I downloaded the free Quickbooks program from their website. That somehow had the missing file that the Pro was lacking and it ended up installing and working properly. Might work for you.
While this can be a hardware issue with the phone, it is probably just a firmware issue. You can do a full flash of the firmware and the issue should be resolved. I would start by going to Nokia support and try to upgrade the firmware software there. If not, search google for the JAF, but this is a hardware device and may cost you, also search google for nokia flash software to try to flash using your computer. If doing a full flash of the firmware does not work, it is probably an IC chip issue and would require it to be fixed on a hardware level.
The best thing to do is send it to a repair centre they will know what to do .you need some programs to recover the sistem .
try this www.satnavservice.com
Most likely the pendrive is no longer working. The simplest way to check that, is to try it in another computer and see if it's recognized. If this is the case then the USB ports on your computer are not working which I doubt.
If it is seen as unknown device that means that the electronics in the flash drive got bad and it is unrecoverable.
