Check page 17 of manual.
FE: OVERFLOW ERROR; Water is overflowing (water level frequency is over 213).If FE is displayed the drain pump will operate to drain the water automatically
LG WM2487HM series Service Manual Error Display
SOURCE: LE ERROR CODE ON LG WM-2277HW
Don't call service, they will rip you off!
See posted titled "LG Tromm WM2277HW will not spin"
SOURCE: "FE" error code; won't stop filling
Hello Sheri Tucker,
The "FE" code is referring to a bad or malfunctioning water valve. The machine continues to fill because the solenoid on the valve inside the machine isn't closing to stop the water. The valve should be inspected and/or replaced if bad. This will require some dis-assembly, if washing machine repair isn't something your comfortable with then a service call is the best bet. If you are going to try and inspect yourself please make sure you unplug the machine before starting any dis-assembly. Hope this helps.
Thanks,
edgin96
I’m happy to assist further over the phone at https://www.6ya.com/expert/ryan_7b238a1b08d97b98
SOURCE: I have an LG WM2487 washer and I'm having several
Addressing your error code: We had the same problem with our washer and couldn't find anyone locally that wanted to even look at it. Hence, I had to find a solution myself. I stumbled onto a sight that had service manuals (not just owner manuals), and found that error code there. What looks like an upsidedown F is actually a lower case T, so the error code is really "tE". This indicates a Thermistor fault.
The Thermistor is located next to the heating element at the botom-front of the drum housing (you will probably have to lay the washer on its back to access it). It is in a soft rubber grommet that protrudes about a half inch out of the housing, just to the right of the heater.
In the case of our washer, when I pulled the Thermistor out of the grommet I noticed some rust on the metal part. I simply rubbed the rust off with my thumb, inspected it again, unplugged and re-connected the connector a couple of times, and tested the washer again.
Results: We have now been using the washer for a couple of days with zero errors, and this was a tenacious fault that interrupted every load before. We are finally happy again with our very expensive appliance. I sincerely hope that this helps you and anyone else with this problem.
SOURCE: My LG WM2487H has water in the detergent cup at
This is normal.
All LG washers use a siphon system to dispense soap, bleach and fabric softner.
Some times water will remain in the cups depending on the cycle used.
SOURCE: "FE" Error code on Lg Washer #2277HB
FE means overflow condition. That means sand or trash has gotten into the tube going from tub to water level switch. So find that hose and blow it out. Remove the standing water and retry.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
