SOURCE: Wont start.
Remove and clean the carbs. Also clean the water trap on the petcock, (gas valve), if your bike has a water trap. Remember to balance and sync the carbs after installing.
SOURCE: 1979 suski 750,bike runs on 2 left side cylinders,
Hi and welcome to FixYa,
With the indulgence of craigjamesbt...
A few additional ideas to consider:
Would appreciate a postback on results/updates on any developments.
Good luck and thank you for using FixYa.
SOURCE: 1986 Kawasaki Ninja won't fire
Theres fuel starvation, the carbs are not getting required fuel in other words the float chambers doesnt get the correct amount of fuel .
Check the fuel flow from the petcock to the carburators.
Check the float pin and adjust accordingly to get the right level inthe float chamber of each carburator.
Hope this helps!
SOURCE: 1986 Suzuki GS 450 won't start
Take the carburetors apart and either rebuild them or clean them thoroughly.
