Sharp LC52E77UN 52 in TV Logo
A
Anonymous Posted on Sep 28, 2013
Opc light and power light blink then power light blink and pattern repeats
5 Related Answers
Anonymous
  • 53 Answers
  • Posted on Mar 14, 2008
SOURCE: No picture, but power is on...
How many times does the POWER led blink per sec? (dont worry about the OPC)
2x = power supply (not as expensive to fix)
3x = Main board (expensive to fix)
Anonymous
  • 1284 Answers
  • Posted on Jan 07, 2009
SOURCE: Blinking power and OPC lights
If you have tried to reset the TV by unplugging it for 2 minutes and still have the same issue then it is time to bring the set to a repair shop.
Chi Chu
  • 8457 Answers
  • Posted on Jan 05, 2010
SOURCE: My sharp LC-37d62u display problem
This problem very common in sharp tv.The POWER,OPC flashes.First turn on have power LED indicator light stable at all? Tries the power again couple times will have backlight come back on,than it will work.Not at all more than 5-6 times than ur main turner signal board is the problem,must replaced.
Testimonial: "Took a part back panels looking at the circuit board power capacitors, plugged in TV to power outlet, and powered up normally."
Anonymous
  • 41 Answers
  • Posted on Feb 25, 2010
SOURCE: Sharp LC-37SB24U will not turn on
From the information you have provided failed capacitors in the power supply is likely causing the problem. The safety circuitry shuts the TV set down when it detects a problem. This model of TV has over 2,000 parts which include millions of transistors inside the integrated circuits. The capacitors will change value, leak and become defective. Resistors will change value and burn. Integrated circuits and transistors can go bad. This can cause other components to become defective, which can have a domino effect and cause other parts to fail. Replacing one defective part may make the TV operate for a short time but the part will fail again since if the parts that caused the failure to begin with are not replaced. The only way to know for sure what is causing the problem, which parts that are no longer within factory specs and for proper repair all the electronics must be diagnosed by someone with the correct electronic test equipment and the skills to use the test equipment. The repair should cost about $250 if carried into a TV repair shop. A small TV repair shop will often charge less than a large repair facility.
Chi Chu
  • 8457 Answers
  • Posted on Apr 17, 2010
SOURCE: My Sharp LC-42-D62U won't power up. The power
Ur Tuner signal board have problems or dead.Ur power LED light indicator stable for a few mins before the power LED light,and the OPC LED light indicators flashes?After the POWER light and OPC light indicators flashes,just push the power button again for the power recycles again.Probally have to pushes the power button 3 or 4 for power light and opc light indicators flashes,the LCD backlght will lght up and work.Sharp tv have this problems alot,very common in Sharp LCD tvs.
Sharp TV model LC-46D64U. Power and OPC lights blink together then the power light blinks alone....repeat. Does this blinking pattern suggest one board over another?
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
1helpful
Sharp power opc light blinking three times
The code that is flashing usually points to a main board failure. I would recommend getting it diagnosed. If you want to be gutsy and try and replace the main board yourself, MAKE SURE YOU GET A BOARD THAT MATCHES YOUR PART # EXACTLY. Sharp makes several revisions of main boards for various models, and they ARE NOT compatible.
So when i turn on my sharp hd it turns off then the opc light comes on! Then the power light and opc light keep flashing!! Alls i want 4 it to work? Plz help
The television has gone into a coma. It is going to need to be serviced or replaced. The blinking code is a pattern. If you look at the power light and the opc light separately and independently, you can acquire the blinking pattern. Cover opc and look at power only. Note how many times it is blinking before it pauses. It might just blink steadily. Next cover power and look at opc alone. Note how many times it blinks before it pauses.
Depending on which model you have it might work if you leave the television unplugged overnight. The next day plug the television back in and wait for the blinking to start. Hold down the power button on the side of the television until the light stops blinking and turns red (usually right away). Let go. Press and release the power button once more and the light should turn orangish and then green. The television should turn on.
You can call Sharp and have a case file created and try and INIT with the customer service representative.
1helpful
2answers
I have an aquios LC-42D64U which suddenly has the following two lights blinking power & OPC. They both blink, once together, the second blink is only the power, and repeating the sequence. I've...
Sharp LED/LCD EEP cleared Step 1 Remove Mains Plug 2 Press On/Off Switch from LED/LCD Panel 3 Press Ch Down & Input Switch together and plug in mains cord 4 LED/LCD will start 5 "K" will appier on Screen 6 Press Ch Down & Vol Down from LED/LED Panel 7 1/9 Page will appier on Screen 8 Go to 9/10 page by pressing Up & Down arrow of remote 9 Select EEP Cleared 10 Press ok button from remote 11 On Screen dispay EEP running 12 Remove Mains Plug after complete EEP Run 13 Restart LED/LCD
2helpful
2answers
TV won't turn on
the first thing that you need to do is to open the back cover of your tv.Go to the power supply section it is separate board where the power cord is connected.Using a multitester,plug in the power cord and measure for the output supply.see if the 5vdc ,12vdc and 24vdc are present..if one of this output is missing,replace the power supply board But if the output voltage are complete,replace the inverter board,It is a board that supplies the high voltage to the backlights of your monitor/screen....You can also try to reset the system of your tv by pressing the the small switch mounted on the main board press it twice while the power is on...tnx and good luck!
please vote for my help!
2answers
Sharp Aquos 46D43U no pic no sound
I have the same problem right now and i dont understand the solution. help?
3helpful
2answers
Top Sharp Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
