SOURCE: Kodak EASYSHARE 5500 will not print with black ink
Here are the things you will be asked to try if you call support. They may fix the problems as well. Taking the printhead out and putting it back in is the big helper.
Remove the black and color ink cartridges.
Right above where the black ink cartridge was, in the top left hand corner of the printhead, push up towards the ceiling and you should be able to push a button that releases the printhead.
Place the printhead right back into the printer and push straight back on the back wall.
You should hear a loud snap.
Replace the ink cartridges which should snap as well.
Close the printer.
After about a minute or so the printer will ask you to do a calibration.
Insert a paper and press start.
Scan the calibration sheet.
After that, in the menu, do a printhead clean.
(If this is a 5100, do it in the home center ->? in the top right ->Maintainence ->Clean Printhead.)
Do one basic and one deep.
Print a demo sheet to see if anything has changed.
If the picture looks better, continue to do cleans.
In the event that it does not, the printhead will need to be replaced and since the printer is still under warranty, Kodak specialists will try to overnight you a printhead.
The whole process is short and free.
The number for Kodak AiO Support is 1 800 421 6699.
SOURCE: picture prints too pink
What you see on the screen is quite often not what prints. Sometimes the screen will not show a slight color anomoly. If your pictures were taken with a digital camera, this is quite common. Try the photo enhancement software that came with your camera, or alternately, your printer. They all supply the software because of color corrections that are at times necessary. Sometimes always. Hope that helps. Try the "Auto Correct" function that most photo correction software has. That should help!
SOURCE: Kodak esp 3 all in one. colour prints come with purple tint
Surely you can turn the flow of ink down via your settings
SOURCE: new kodak esp5250
Try to clean the printhead
Press Home > Maintenance > Clean printhead
If still the same issue
Visit www.kodak.com/go/itg
IF still same issue call or chat with tech support and get the printhead replaced free of charge
SOURCE: Kodak 5300 printer: I just changed the black ink
From what i understand with the kyocera colour printers theres a menu option to print black as black opposed to a combination of the colours. I'm not too sure where it is, however it sounds like the kodak is very simular and is using the colours to create black instead of using the blank ink cartrage.
