Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
Posted on Sep 20, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Prob in PC
Hi sir,......... I have installed Windows Xp OS..... But if i say shut down,.. sometimes is running service.exe and after anding that, it goes to shut down process..... after all process like saving settings, and all it says win is shutting down... but it is not shutting down... I shoud mannually switch off the button.... Can U tell me what might had happened?..... and suggest me some tips
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 293 Answers
  • Posted on Sep 20, 2007
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
293
Questions
0
Helped
248381
Points
718
Are you using an installer with SP2? check your devices under my computer if all are ok.
Code 1699
Sir
Please apply below instruction To remove Hp service error code 1699:
  1. Copy the file hpp1284.exe to the root directory of the user's PC. In most cases, this is the C:\ drive.
  2. Shut down all applications running on the PC.
  3. Shut down the HP LaserJet 1100A Document Assistant by right-clicking the tray icon and selecting the "close" option.
  4. Click the Windows 98 Start button and select the Run option.
  5. Type in the path to the hpp1284.exe file, along with the name of the file. For example, "C:\hpp1284.exe".
  6. Push the OK button on the Run dialogue.
  7. After the patch program dialogues disappear, restart the PC by clicking the Windows 98 Start button and selecting theShutdown option.
  8. After the PC restarts, the user may delete the hpp1284.exe file from the PC.
I Hope your Hp printer error is resolved by now:
or
In case you need Online third Party assistance Then follow Us on For:
HP
I use hp nx9010, i want to re-install windows xp but any time i try, the machine shutdown. sometimes is able to move up to copping files sometimes not then shutdown; i don't understand why is only windows...
well that is so easy to answer,
first off you are not using real HP disks are you.
sure. its old Blue Microsoft disks right,
and when you do that wrong, you get no HP chip drivers and lost more missing, even top row, fn keys dead, not just audio.
XP is a dead OS. for 3 years now, zero updates and is now a virus magnet extream.
nx9010 note book shuts down, all 3 os install different. !
old XP runs a very old and very DUMBB seteup.,exe
the newer OS run WINPE for setup.exe. vastly better and boots and loads the OS totally different.
Xp can be installed many ways, not one stated by you.
1-insert, HP install disk in CDROM drive and click, setup.exe running in a XP explorer window, live install
2: boot to HP install disk.
3: boot and hit F11 run HPs on HDD restore partition.
4: same as a above 1, or 2, but is Micro soft disk (wrong, you did it wrong, do not use mS disk) if must ask how, its a long long long story. ive done it all ways, 1000s of time. now since first PC.s ever.
if booting to XP , right or wrong CD. (its a CD right<)> or a stick
that too not stated,
it boots and you answer questions, then it starts copying
if it stalls that means, the CD is bad.
or PC is bad, you do know there are 3million transistors here to fail right? bad HDD, bad Mobo, and more. lots more
even the CPU can over heat and will shut down.
Personally I avoid all CD nows, they sux'd then and do now more.
make and ISO of your CD, (ask its easy and free)
then burn the ISO to a 4GB or bigger uSB memory stick using free RUFUS app.
boot to stick. on my HP hit F9 and pick Udisk USB. boot
bingo no more CD errors ever again.
i bet bad CD. seen it vast times, endless , but not today. too savvy now. to mess with any CD, if you copy it to ISO and get CRC errors
its a bad CD.
end pain.
the problem with real old PC most cant boot to USB
or must be BIOS flashed updated to get that.
ill now ill try to learn what yours can or can not do.
lacking ,what is there now.
but id do this first. go in to BIOS BOOT PAGE
What is the default boot order? The default boot order settings for the computer are configured in the factory. The default boot order for HP notebook PCs is listed below.
  1. Floppy disk drive
  2. Optical drive (DVD, CD-ROM)
  3. Hard drive
  4. USB device (see this?) bingo, can boot and install any OS here
  5. Network adapter
Hav to change my os
hi sir. its eay to install the xp. First format your pc and then boot it with xp cd if you have the XP cd. else you can download the windows XP from the following link:
http://www.softwarepatch.com/windows/windows-xp-service-pack-3.html
or
http://www.soft32.com/download_123572.html
all the best..
2helpful
Dll driving me nuts
Hello EricS777
The part where it looks like your xp stuff and vista stuff switch drives is normal. Only the Operating System associates the hard drives by letters this does not mean your hard drive files are switching. This happens because D: drive is Root of Vista OS and Root of any OS in windows gets the C: drive lettering.
dwwin.exe, drwtsn.exe dll is the "Microsoft Application Error Reporting" tool.
I think the message means that something is crashing during system shutdown. When the crash occurs the OS launches dwwin.exe to report the error, however the windows operating system is shutting down and so the application can't launch make the system lockup or hang.
Your problem isn't with dwwin.exe, you need to find out what is actually crashing at shutdown.
If you can`t find out what it is, try going to Administrative Tools/Services and disable the “Error Reporting Service”. You don`t want that running anyway.
Also right click My Computer/Properties/Advanced/Error Reporting
Put a check at both
Disable Error Reporting
But notify me when critical errors occur
Then, if that was the cause and the message stops, we`ll have to try to identify the cause.
Sir i am a dealing in notebook. i purchased a compaq presario cq60 104tu .. and also license win xp sp3 . but when i started a boot from that cd ... it dosent work and it showing a blue screen... ( press...
your in windows xp and youre try to install sp3 from a disk i take it.
either the disk is corrupt,missing files or wrong version .causing blue screen.(fatal exception)
you could try leaving the disk in and reboot ...
when in windows select run D: or what ever letter is assigned to cd drive .( start , run , type in d: and enter)
this will show files on cd/dvd. drag and drop the .exe program into a file or on desktop and try to run.if it runs the cd/dvd is the prob (corrupt,virus,missing files.) if it does run its the software incompatable or faulty(incomplete files or wrong version)
either way the cd will be useless.
you can download sp3 (free)as long as you are using a registered os.
Explorer.exe uses all available CPU
Norton anti-virus is a resource HOG. Disable it from running at start-up. It may be trying to download updates as the pc is booting. Use AVG anti virus, it is free and works very well.
Problems in Downloading & installation of Driver 640c.
Hi Deepak,
I think you have downloaded the driver for windows XP 32 bit OS, and i think that your PC supports Windows XP 64 bit Operating System.
Click here to download the software for Windows XP 64 bit Operating System.
DOWNLOAD (x64Drv5.64.0.17.exe)
Installation Instructions: USB Connection
1. Download the x64Drv5.64.0.17.exe file.
2. Once downloaded, choose Open or just run the x64Drv5.64.0.17.exe.
3. Follow onscreen instructions listed below.
Note: There may be a long pause between each of the steps below.
4. Choose Direct Connect.
5. Power on the printer, and connect it to the computer when prompted.
6. The "Found New Hardware Wizard" will be displayed.
7. Select No, not this time.
8. Select Install the software automatically (Recommended).
9. Depending on your product, you might see one or more Windows' warning screens.
10. Click Continue anyway or Yes each time these Windows warning screens appear.
11. Click Finish.
12. Reboot your computer (Highly Recommended).
Installation instructions: Wired and Wireless Network
2. Once downloaded, choose Open or just Run the x64Drv5.64.0.17.exe.
3. Follow onscreen instructions listed below:
4. Choose Network.
5. Choose your printer after the installer has identified it on the network.
11. Click Finish.
Thanks
Rizz
IBM Think pad T22 problem
Hi
Check your laptop CPU fan is running if no replace it. Problem is because of over heating....
Thanks
2helpful
10answers
Acer laptop aspire 4710z config my notebook have problem
hello ramavtar..
i have a acer aspire 4710z. This laptop can not open the display but the system unit is working normally. i can not see the display but i can join the external monitor i will see it process. Pls let me know how can i repair it.Pls reply to this email thanks. [email protected]
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
