HP LaserJet 2420 Printer Logo
David Sanchez Posted on Dec 03, 2017
Connect airport extreme
I wanted to connect my hp2420 printer to my airport extreme so that I could be able to print wirelessly via the airport extreme. Is this possible? I have the 2 connected and the airport extreme does not seem to recognize the printer at all. it does recognize my 2 hard drives that it is connected to via a usb splice. thx
3 Related Answers
Anonymous
  • 495 Answers
  • Posted on Jan 13, 2009
SOURCE: hp C3180 printer. Macbook
Please visit this site to setup your wireless, something might be going wrong.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=115&prodSeriesId=25563&prodTypeId=18972&objectID=c00592751
Anonymous
  • Posted on Feb 09, 2009
SOURCE: connect my printer to my laptop via wireless router
yes
Anonymous
  • 254 Answers
  • Posted on Apr 01, 2009
SOURCE: hp6310 won't print wirelessly with apple airport
the air port is faulty.the port will be loose internally connect it properly.
its a common cause in airports.
How can I connect my Imac with my Toshiba hdtv Series V4210U via airport extreme?
Does your Toshiba have a wireless adapter? If so, you can set up a home network, if you don't already have one. If no,Does the iMac have a VGA or HDMI connector? You can connect via a adapter cable, Vga to HDMI or a HDMI cable, depending on the iMac connections.
Bought a new macbook air and want to install my Color LaserJet CM1312 MFP. when connected via USB the printer prints. however if i use the set up assistant, the printer is not recognized. can not install...
Deleting the printer and then reinstalling it using the Gutenprint Drivers for the HP 1300 Series in the Add Printer pull down will allow you to print B/W. This works wirelessly over an Airport Extreme, so I assume that it will work wired. I am searching for a solution that prints in color. Amazing that HP and Apple seem content to orphan such a widely-used and relatively recent MFP.
Mac user can't scan on Dell MFP 1600n
That's because you can't scan over wireless. In order to scan, you need to be connected via USB, so I hope you've got a MacBook...
HP DeskJet D2460 only prints grayscale through Airport Extreme
did you try going to printer properties? i think you will most likly find your answer there.
Wont connect to each other
connect the airport extreme to the voyager using a network cable... factory reset the extreme and then connect to it using the airport utility... you should get a setup screen where you can switch the extreme to "bridge mode" .. everything else should happen automatically.. you will then have 2 wireless networks?
Airport Extreme Bases Station not detectable with utility
This depends... Reaching them wirelessly may be unreliable for a number of reasons, so, I'll proceed on the assumption that you are attempting to test in the simplest lowest-variable situation:
First, make sure that you have the latest Airport Utility for your Mac.
Connect your Mac to the Airport via a single Category 5 (or 5e or 6) cable. Factory-reset the Airpot and then wake up the Mac. If the utility still can't discover your airport, it's probably time for a trip to your local Genius bar as you most likely have a hardware problem.
Lather, rinse, repeat for each of the two airports.
1helpful
Does HP laserjet 1020 work with Airport Express
I removed any printer configurations for this printer in both my pc and my mac (both usb and wireless). Then I restarted both computers and added the printer via usb again to each. At that point I went back to the extreme configuration and under the printers tab it was finally seeing Hewlett Packard Laserjet 1020. After that, adding via Bonjour went smoothly on both platforms.
2answers
Can't print to mac wirelessly (could do it a few days ago)
I had the same problem until recently. You have to install the drivers FROM THE CD that came with the printer, instead of selecting the drivers from the default list. Then, when selecting which printer driver to use (you'll have two options) choose Canon IJ and NOT Canon MX310 series. This is a problem with their MX310 driver, which is solved using a default/generic Canon InkJet (hence, the IJ) driver. Hope this helps!
P.S. This only works on Mac OS X. I have yet to figure out how to print wirelessly through Vista. Will keep you posted.
k24674
Grand Canyon Tech
Grand Canyon Tech
