SOURCE: Sony Bravia 40" LCD TV generating heat.
First, you will have to define what you mean by "hot to touch" ie.:
can you or can you not hold your hand on it for a few moments.
SOURCE: sony bravia-flashing red light
I would guess your power supply board is slowly disintegrating. It is hard to tell what it is, until it finishes frying itself out. Plan on replacing the power board soon, 1-3 months maybe.
SOURCE: my sony bravia tv is flashing red stand by light
Try leaving the TV unpugged for 30 minutes so the TV can reset itself.
If that doesn't work, most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you flashing red light codes, circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
SOURCE: Sony BRAVIA volume problem
I had this same issue, and solved it by putting the TV in "Theater Mode', which can be acheived by hitting the "Theater" button on the remote.
